Onan Older 2 Cylinder Needs Help!
this thread has 12 replies and has been viewed 2577 times
Old 09-25-2018, 02:00:49 AM
cobbadog cobbadog is offline
Default Re: Onan older 2 cylinder needs help!
Can't see any reason for 2 condensors in the one system. Maybe one failed and a replacement fitted elsewhere and wired in place there. I have been using film capacitors instead of condensors over the last couple of years. These are more reliable and can be very small in size but big in capacity so they can be fited almost anywhere. I prefer the ceramic ones over the plastic ones just as a heat shield issue. Try using one with values of 600V and 0.22Mf. No positive or negative sides just insulate one side going to your points with plastic or shrink wrap.
Old 09-25-2018, 09:38:32 AM
JLiebermann's Avatar
JLiebermann JLiebermann is offline
Thank you cobbadog for you help. The second condenser was attached outside the breaker box. I dont remember who/when I had work done on this engine last. It has not been in use for the past 8 yrs or so but did not run correctly when I tried to start it.
Anyway I ordered new points, condenser, and coil and they sent a condenser that matched the one that was attached to the outside of the breaker box.
The engine does not run with the inside condenser removed from the circuit so I am going to replace the coil now and take the cost hit.
Hopefully the pic got attached.
John Liebermann
D69U, D69U, IHC544, Ford860, D25J, Hardie Spray Rig, 67Chev C10 Short Narrow Box, Dodge Cummins 1990 W250
Old 09-26-2018, 02:17:20 AM
Default Re: Onan Older 2 Cylinder Needs Help!
Good news that you have resolved the mystery about the extra condensor. Interesting in your picture that both the points and condensor look very similar to those used on our very early Victa 18 lawn mowers. Those ignition parts were made by Wico out here.
ONAN Trying to identify an older single cylinder Onan joeaksa Onan Generators 12 08-15-2015 11:10:51 AM
Should I buy this 15 kw Older Onan genset? ocman Onan Generators 5 09-10-2010 11:17:41 AM
Older ONAN 5ACK thefonz6752 Onan Generators 4 02-28-2009 07:07:18 PM
Indentifying older ONAN signgroup Onan Generators 8 01-29-2006 11:18:32 AM
Older Onan Followed Me Home........ midpw Onan Generators 4 05-24-2005 01:44:17 PM
