Mogul Jr. Accurate 'M' Mag Issue
this thread has 2 replies and has been viewed 234 times
Old 09-01-2018, 09:06:57 PM
Kevin Weis Kevin Weis is offline
Default Mogul Jr. Accurate 'M' Mag Issue
My Accurate 'M' magneto fires sometimes and sometimes not. Changing the mag timing in the gear ,enshrined or trip timing makes no difference timing is just as in the owners manual. Thinking the magnets are just a little too weak causing the inconsistent spark or maybe the contact on the commutator is too worn or both. So any thoughts appreciated. Kevin
Old 09-01-2018, 11:12:44 PM
Card Sponsor
Default Re: Mogul Jr. Accurate 'M' Mag Issue
Have you run the engine on a battery and coil to rule out the mag in cas it's an ignitor problem? The commutator may be dirty or the brush worn. Rob
Old 09-02-2018, 10:31:31 PM
Rob, igniter works fine on battery and coil. The brush on the commutator does appear worn. Commutator itself looks fairly clean. Thanks.
Accurate Type O JWithers Magnetos, Ignition Coils and Spark Plugs 7 10-01-2018 04:50:07 PM
Mogul 8-16 Compression Release Issue tirediron Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 11-08-2015 01:08:02 PM
Accurate mag What's it fit Rob Charles Antique Engine Archives 0 09-05-2003 11:28:04 AM
Accurate Mag question Dan Bogart Antique Engine Archives 4 07-20-2003 11:45:50 PM
