Wisconsin Engines
VF4 Polarity
this thread has 5 replies and has been viewed 402 times
Old 06-21-2019, 09:18:52 AM
Thmpr Thmpr is offline
Default VF4 Polarity
New member here trying to resurrect a VF4 s.n.2435994. Can someone confirm battery hook up? One faded red battery cable goes to ground, and the other gray one goes to starter button, leading me to believe it is positive ground. The terminal clamps were pretty beat up so couldn't determine by size. I have not been able to access the wiengines.com site. Thanks.
Old 06-21-2019, 01:19:59 PM
radiodoc radiodoc is offline
Default Re: VF4 Polarity
Thmpr I am pretty sure it is positive (+) ground. Check the wiring diagram on page 14 of the manual. https://books.google.com/books?id=ei...page&q&f=false
Old 06-21-2019, 02:27:36 PM
Thank you, Radiodoc. I did not have a manual - that will be a big help.
Carl
Old 06-21-2019, 03:01:15 PM
I believe on that page there is a place to click and download the manual...it's in PDF format.
Old 06-28-2019, 12:07:59 AM
K-Tron K-Tron is offline
Carl, Your engine was built in April of 1955. Since your engine serial number is in the 2,000,000s it is very likely that your engine has a positive ground and is a 6 volt system. That would mean that your engine is wired correctly. Positive to ground, negative to one side of the starter switch. The wire on the opposite terminal of the starter switch should go directly to the copper terminal on the side of the starter motor.
Old 06-28-2019, 01:38:46 AM
It might be a good idea to polarize the generator before starting it, just in case someone has switched it to a negative ground polarity in the past.
Starters, dc generators, mechanical voltage regulators, and points ignition systems will all work equally well with either polarity. Sometimes the regulator contacts (and points too?) were optimized for one polarity, and will not last as long the other way around.
With the battery connected, briefly (a couple seconds is plenty) connect the Armature and Battery terminals on the voltage regulator with a piece of wire, and you'll be all set. If there's an ammeter, make sure it shows charging when the engine starts.
SA-200 polarity Azcopper Welding Shop 2 11-18-2014 10:51:44 PM
battery polarity cooter 1954 Onan Generators 6 09-01-2011 08:32:52 PM
Wico EK Polarity? Jon Mrozinski Magnetos, Ignition Coils and Spark Plugs 8 01-08-2011 10:14:42 PM
Spark Polarity K D Redd Magnetos, Ignition Coils and Spark Plugs 3 10-25-2010 06:54:26 PM
Magnet polarity DippyNo12 Hit & Miss Gas Engine Discussion 4 01-10-2007 12:47:10 PM
