Wisconsin Engines
Wisconsin Parts Never Been Used for Sale
this thread has 65 replies and has been viewed 28457 times
Old 08-17-2018, 11:29:31 PM
joeschroep joeschroep is offline
Default Re: Wisconsin parts never been used for sale
Hi ! I am a new guy so bear with me, I have a Wisconsin vh4d and it needs rebuilding or replacement, as well as a shroud and air cleaner bottom. Ay help you can provide will be appreciated. Thanks,
Joe S.
Old 05-06-2019, 01:33:02 PM
boone007 boone007 is offline
have lots of agnd parts thanks dan!~
---------- Post added at 01:33:02 PM ---------- Previous post was at 01:31:40 PM ----------
i have lots of agnd parts thanks dan !~
Old 05-10-2019, 09:49:18 PM
IndianaDundee IndianaDundee is offline
Default Wisconsin VH4D rebuild
Is this thread still active? I have a VH4D that is giving me fits to get running right. It just blew a head gasket and cracked a cylinder block. I don't want to go thru the expense of boring and bigger pistons but if I could find new cylinder blocks for cheap that would be great.
Old 05-11-2019, 09:35:46 PM
DCamp DCamp is offline
Default Re: Wisconsin VH4D rebuild
I will check in the morning to see if I have a good one.
Old 08-01-2019, 10:56:03 PM
littlebit littlebit is offline
Default Re: Wisconsin Parts Never Been Used for Sale
Jersey Mowers .. I am in need of a Zenith carburetor for a Wisconsin BKN 7 hp. If no carburetor do you have a kit with float. Any help appreciated.
Reply to drdathomas1@aol.com. Thank you kindly!
Old 09-18-2019, 08:13:14 PM
airboat airboat is offline
Originally Posted by JerseyMowers View Post
My father owns a small engine repair shop that was originally started by my great-grandfather. They were once a Wisconsin/Wisconsin-robin dealer and over the years stocked many of parts which are still on the shelf. I have consolidated many of the parts and have no use for them and was wondering if their is anyone still interested in rebuilding the old Wisconsin motors. The parts consist of a range of pistons, rings, connecting rods, cylinder heads, head gaskets and gasket sets, carb repair kits, carb air horns fuel tank brackets, engine shrouds, fuel pumps, valves, valve springs, valve spring retainers, shell bearings, a few ignition components, engine instruction manuals, and miscellaneous parts and more. Most of the parts fit models AGN, AENL, AEND, VG4D, VH4D, TJD, THD to the best of my knowledge. If anyone is interested i can send a file with part numbers and descriptions and can also take pictures if needed. We also have a collection of Wisconsin-Robin parts I have not sorted yet if anyone is interested, thanks for looking.
Jersey Motors looking for a piston rings for AGND wisconsin motor 3.5x4please email airboat20022002@yahoo.com with price an shipping thank you Ron
For Sale Engines and Parts Crossley Kid Smokstak Down Under 0 10-06-2015 08:43:38 PM
wisconsin EY27W for sale Huey1969 Wisconsin Engines 0 12-22-2011 09:02:23 PM
For Sale 4 old Tractors for Parts jrh Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 04-26-2010 03:25:18 PM
Case parts that may be for sale Grape Steam Stationary Engines, Traction Engines 12 06-24-2009 12:17:00 AM
