John Deere D Magneto Trouble
this thread has 6 replies and has been viewed 3965 times
Old 11-29-2012, 12:44:26 AM
1929 John Deere D 1929 John Deere D is offline
Default John Deere D Magneto Trouble
Hi Guys!
I have a 246T splitdorf mag for my 1929 John Deere D that i have jut put in a new condenser. It sparks fine when i hook it up to a drill and spin it over. When I crank it by hand i get 2 sparks 2 misses and 2sparks and 2 misses again and so on. Is this normal. I have a wico C base mount that sparks everytime. I'm really not sure what to expect. Is a magneto supose to make a spark everytime? Any help is appreciated
Old 11-29-2012, 01:35:25 PM
Danny Danny is offline
Default Re: John Deere D Magneto Trouble
I have a Edison Splitdorf Mag on my 39 H JD. It sparks twice then misses twice. It is suppose to work that way.
The Following User Says Thank You to Danny For This Post:
Old 11-29-2012, 01:52:51 PM
stufforbud stufforbud is offline
If you have the correct dist. cap on it you will get a spark out of the top 2 terminals and the position where the bottom terminals would be are grounded in the cap to the frame so as not to overheat and damage the coil.
Bud
The Following User Says Thank You to stufforbud For This Post:
Old 11-29-2012, 01:56:37 PM
Larry from Maryland Larry from Maryland is offline
Wico mags have no reduction gear and spark every turn.The splitdorf has a reduction gear and only sparks half as often.
The Following User Says Thank You to Larry from Maryland For This Post:
Old 11-29-2012, 02:33:00 PM
Forrest A's Avatar
I would trade you for my wico C base mount that sparks every time if you would like that better... I am kidding of course.
Old 11-30-2012, 08:09:59 PM
Dempster Dempster is offline
The Dixie Splitdorf like yours and Edison Splitdorf CD mags for JDs are made to only spark on the compression stroke so have to be timed that way to #1 compression. The Wico C and XH mags spark on compression and exahaust stroke and if you get them out of time 180 can just switch wires and usually go on but that won't work on a Splitdorf or the early Fairbanks Morse DRV2 mags.
Old 12-01-2012, 08:11:59 PM
Online Splitdorf and other magneto info:
http://www.oldengine.org/members/die...s/MagData3.htm
http://www.oldengine.org/members/die.../Petrolmag.htm
Trouble starting John Deere 1 1/2 hp engine slade12178 Hit & Miss Gas Engine Discussion 16 07-23-2017 03:22:11 PM
John Deere 5c plow, having trouble finding parts. Plowman Farm Antiques and Collectibles 10 11-26-2011 09:21:18 AM
John Deere 1 1/2 E Governor Trouble Butch50 Hit & Miss Gas Engine Discussion 7 11-17-2011 10:43:35 PM
Mid 70's John Deere 110 trouble! Johnchukoloski Garden Tractors and Mowers 7 02-07-2010 11:36:01 AM
John Deere type E fuel system trouble Tom Antique Engine Archives 6 08-02-2004 12:24:14 PM
