binder 4 hp carb ?
this thread has 3 replies and has been viewed 904 times
Old 03-04-2004, 03:57:31 PM
ron brown
Default binder 4 hp carb ?
schebler carburetor, my instruction book says there is a auxiliary air valve adjustment on it ,but mine dose not have one ,no spring ,valve,or adjustment like picture in repair manual it just has a pipe plug in bottom of air intake pipe ,will it run ok like that or do i need to try and find one . if so dose anyone know where i might get one at . thanks ron brown in central ill.
Old 03-04-2004, 06:41:07 PM
Jim Brown
Default Re: binder 4 hp carb ?
Ron: It should have one, like the diagram in the manual. It is a little hard to tell from the picture posted, but your carb has been "modified" in a couple of places. I can't tell what is in place of auxiliary air valve, but it isn't right. Also, in the bottom of the bowl, the drain cock is not original - it looks like it is from a later sediment bowl. The original is a brass petcock - it should be shown in your manual also. I can help you out with the auxiliary valve. Jim
Old 03-04-2004, 10:49:20 PM
ron brown
thanks jim i will email you for details ,ron brown
Old 03-07-2004, 10:50:10 AM
ron brown
jim if you have time please get in touch with me i sent email i dont know if you got it or not? i shure need your help , and to talk to you if i had a phone number , my number 217-563-7405 thanks ton brown in central ill
Carter dr-o carb new way binder engine chuck w Carburetors, Mixers, Fuel Pumps and fuel delivery 1 03-27-2016 04:54:27 PM
Brass Marine? Unknown Carb + E38 carb part? Dominiong Hit & Miss Gas Engine Discussion 3 11-21-2015 12:41:30 PM
Cushman binder carb question Zira Hit & Miss Gas Engine Discussion 3 06-27-2014 06:32:20 PM
John Deere corn row binder & IHC row binder Jim Deakin Horse Drawn Equipment 4 05-23-2014 09:13:18 AM
Need info on Schebler Carb for a Binder engine Chuck R Hit & Miss Gas Engine Discussion 3 07-30-2012 11:05:31 AM
