Smokstak Down Under
Farm Pumper - newbie help
this thread has 51 replies and has been viewed 8103 times
Old 10-08-2013, 10:00:46 AM
Paulwolf350 Paulwolf350 is offline
Default Farm Pumper - newbie help
Gday, I have just purchased a Southern cross farm pumper and need some help locating some parts to restore it.
I am still trying to tear it down to see exactly what I need, but at this stage it will defiitely need a new head and valves (rusted beyond repair), and the rocker gear (missing).
everything external is in prettty good shape, but the barrel may also need to be replaced (more rust). Trying to loosen the piston up at the moment
here is a photo of it on its way home
anyone know where i can get parts for this?
Paul
Old 10-08-2013, 01:08:58 PM
Ironsides Ironsides is offline
Default Re: Farm pumper - newbie help
I think I have a barrel in the shed Paul,cost me $20, so that is what I would need to get back.Postage may be a killer,Norm in Bunbury WA.
Old 10-08-2013, 04:54:46 PM
Tom G Tom G is offline
I believe that this engine is either a re-badged Fuller & Johnson farm pump engine, or a close copy. You may be able to use Fuller & Johnson parts, which turn up from time to time. Getting them shipped to Australia might be expensive, though!
Old 10-08-2013, 09:29:09 PM
Hello Paulwolf350,
Fairly sure Southern Cross built their own copy of F&J's for many years, so there are a few about. Rosebery also made them here and there may be other makers. The good news is that many parts will interchange.
At worst I think you could get the head re-facd and valve inserts fitted. A good shop can modify other valves or make them from blanks. You have springs and caps there. Correct springs are critical. You may find some Aussie owners with spares and advice on the TOMM forum. Worth a try. Good luck with the project. Combustor.
Old 10-09-2013, 01:28:14 AM
Thanks For the replies, I found the TOMM forum last night, so will shoot an enquiry there too. The head is pretty nasty inside, it could be welded up, inserts etc but I was hoping to start with a better one.
Granted, I have only just started but the rocker gear seems to be missing on all the ones I come across, anyone know where I can get the rocker arm and pedestal?
Thanks Norm, will be on touch
Will post some more pics on the weekend
Cheers
Paul
Old 10-09-2013, 01:30:40 AM
cobbadog cobbadog is offline
As Combustor has mentioned many farm pumper engine parts are interchangeable. They come up on eBay a lot and there are still many sitting in sheds in parts or assembled awaiting their turn to come back to life. Have a bit of faith in the bore as these old girls are tough and made of real steel. The unfortunate thing is that parts turn up anywhere and as usual postage is a killer. Ask around at your local Vintage Engine Club as this can be a good source of parts as well as rallies. Talking to as many people as possible is another way of locating parts. I think it is a Company called Vintage Engine Spares at Loganlea Qld. 07 3200 5382. An elderly gentleman named Don Reid is the guru on these. He has helped me out with pumper parts for our Buzacott.
Old 10-09-2013, 01:40:04 AM
Hi Paul,
the same head is used on the Rosebery built 2hp horizontal engines and do pop up on eBay occasionally.
A huge number of Farm Pumpers were built by Fuller & Johnson, Rosebery & Southern Cross so parts do pop up.
Patrick
Old 10-09-2013, 03:44:27 AM
Rob.S Rob.S is offline
Hi Paul
I have got a few pumper parts let me know exactly what you need and I will have a look .Southern cross pumpers have usually got a larger exhaust outlet than the other pumpers .
rob.s
Old 10-09-2013, 07:39:12 AM
Brock Summerfield Brock Summerfield is offline
Email NOT Working
G,day Paul
Rob is right the exhaust pipe on southern cross eng, are 1 inch . buzz, / fuller & johnsons are 3/4 pipe , also the southern cross eng, cylinders are a bit bigger in size not much I think 100 thou .
regards Brock
Old 10-09-2013, 08:57:56 AM
Default Re: Farm pumper - newbie help (chasing parts)
Can someone please tell me how to find the serial number of my engine? Would like to chase down some of the history of it
Paul
Old 10-09-2013, 03:48:28 PM
tim2010 tim2010 is offline
Try looking on the face of the flywheel near the timing mark
cheers
tim
Old 10-09-2013, 10:59:00 PM
Rusty Engines Rusty Engines is offline
eMail NOT Working
AS Tim said on the flywheel RIM next to the timing mark sometimes has the word SPARK stamped on it
I can date it for you
http://www.southern-cross-register.sumpy.com/index.html
Ian
Old 10-10-2013, 12:54:12 AM
Sometimes numbers are on the end of the crankshaft as it is on the Buzacott.
Old 10-10-2013, 07:12:11 AM
Cheers guys, will have a look tomorrow and post up
Paul
Old 10-13-2013, 09:35:01 AM
As promised, some more pics of the pumper
This is the head
And the barrel
Barrel might come good once I get the rust off, but the entire seat is rusted away on my head. Will keep looking before I decide to repair it
Paul
The Following User Says Thank You to Paulwolf350 For This Post:
Old 10-13-2013, 09:52:02 AM
Here are some more tear down pics
Now I just need to work out how to get that bevel gear ( or the smaller crank) off and start cleaning it all up. Hopefully the top end parts I need will start to come to me
Cheers,
Paul
The Following 2 Users Say Thank You to Paulwolf350 For This Post:
Old 10-13-2013, 01:05:29 PM
Paul,do not try and pull that gear off it will break --- sandblast try to keep the sand out of bearing surfaces.Nothing will be achieved pulling that gear,Norm
Old 10-13-2013, 05:44:29 PM
Thanks Norm, I thought as much. The tapered keys are hammered in flush and look like a pain to get out. I will do as you suggested
Old 10-14-2013, 06:02:57 AM
eMail NOT Working
The Southern Cross Farm Pumper were first made in December 1927 with the spoked bevel gear wheel by 1930 it was replaced with a solid one because the spoked one broke to easily
So it is an early engine
Have you found the number
Ian
Old 10-15-2013, 01:59:23 AM
Could the serial number be stamped in the tail of the direction arrow on the flywheel?
Farm Pumper, or not Pumper muzzery Smokstak Down Under 14 06-17-2019 06:51:20 AM
Farm Pumper Adrian Holland Smokstak Down Under 10 02-18-2018 03:27:06 AM
Farm Pumper Phil Dowe Smokstak Down Under 60 12-07-2016 06:58:19 AM
Farm pumper Darryl Smokstak Down Under 5 04-02-2015 12:58:12 AM
F&J Farm Pumper Patrick M Livingstone Antique Engine Archives 0 07-12-2002 10:19:08 PM
