How to calculate ...Pressure it takes to lift a liquid 1 foot, in a hose.
this thread has 8 replies and has been viewed 3949 times
Old 11-30-2013, 03:40:08 PM
len k len k is offline
Default How to calculate ...Pressure it takes to lift a liquid 1 foot, in a hose.
This question seems to come up often enough, so here's the way I remember the answer.
This is just another way of saying what is pressure at bottom of a collumn of liquid 1 foot high.
I imagine a box 1 foot on all 3 sides. Force on bottom is weight of liquid inside (for water it's 62.4 #). Surface area of bottom is 12" x 12" = 144 square inchs. So pressure on bottom is 62.4 #/ 144 sq in = 0.433 psi.
If hose is 10 ft, high pressure at bottom is 10 ft x 0.433 psi/ft = 4.33 psi
If liquid is gasoline, use specific gravity of gas (~.73) to ratio the answer.
Presure of 1ft collumn of gasoline is .433 x .73 = .316 psi
water ----- 0.422 psi/ft ---- (~1/2 psi /ft)
gasoline ----0.316 psi/ft ---- (~1/3 psi /ft)
When selecting pump add extra pressure to account for filters and friction losses of hose, when fluid is flowing.
Hope someone finds this usefull.
Old 11-30-2013, 04:32:57 PM
John Newman, Jr.'s Avatar
Default Re: How to calculate ...Pressure it takes to lift a liquid 1 foot, in a hose.
This gauge from a hot water heating system shows the relationship between altitude (height of water column in feet) and pressure.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 11-30-2013, 07:00:51 PM
JeffK's Avatar
JeffK JeffK is offline
Is that a photo of an electric hot water heater set up as a hot water boiler
Idle hands are the devils workshop
Old 11-30-2013, 07:33:29 PM
Yep. 50 gal electric water heater with a circulator pump feeding 2 heat exchangers hanging from the ceiling. Filled with a 50/50 mix of antifreeze & distilled water.
No gas service (by choice) at the shop. Actually does a pretty good job.
John Newman, Jr.
Saint Louis, MO
Old 11-30-2013, 08:27:54 PM
BlkBeard BlkBeard is offline
Did you change out the OEM Temperature & Pressure Relief Valve in the Water Heater to 30lb Boiler Relief Valve?
Old 12-01-2013, 03:42:23 AM
T&P valve is original. Has never blown open yet. Highest pressure I have seen is 15psi. Water doesn't go over 140°. I have an expansion tank in the loop that is more than adequate for the size of my system.
I ran seperate 10ga feed lines (on seperate breakers) to both 4500 watt elements and can run both at the same time. Both elements have over temp cut-off protection. At $0.10 / KWH it still costs under $1.00 an hour to run including the pump and fans. I just have to remember to turn the element breakers off an hour before I plan to leave so I don't leave a tank full of hot water behind.
John Newman, Jr.
Saint Louis, MO
Old 12-01-2013, 08:32:41 AM
Graycenphil Graycenphil is offline
Is that cheaper, or better, than just running electric heat?
Old 12-01-2013, 09:43:55 AM
The T&P Valve should be changed to a standard 30lb relief valve.
The O.E.M. T&P valve is not designed for operating a Boiler, which is what you've created. It requires far too high of a pressure to Trip.
My suggestion would be to install a Tee in the relief tapping. Install the correct Pressure relief valve in the side outlet of the Tee, and Bush the top outlet to accept a Taco or equivalent Auto Vent.
This will provide Air elimination from the top of the tank, since you now have a "closed system"
Old 12-01-2013, 10:19:14 PM
Now, why would there be air at the top of the tank? Hot water outlet is at the same level as the T&P fitting. System has been running since January 2011.
"...Is that cheaper, or better, than just running electric heat?..."
I get more heat faster than anything else I have tried except the kero torpedo heater. Even burning diesel in it, it still cost $4.00 an hour to use that. This is much quieter, doesn't smell and no risk of carbon monoxide death. Does a better job of getting the heat distributed throughout the building (25' X 90'). I do have a few 6' baseboard heaters along the walls and you do not feel their heat once you get more than about 3' away from them. I am running a couple of ceiling fans to stir things up, too.
John Newman, Jr.
Saint Louis, MO
KGB takes over National Threshers June 27-30, 2013 Beth V Steam Stationary Engines, Traction Engines 46 11-14-2013 11:34:30 PM
Emerson Foot Lift Plows John Brantingham Horse Drawn Equipment 0 10-18-2012 12:32:01 PM
How do I calculate discharge rate needed for a boiler? MarkP Steam Stationary Engines, Traction Engines 10 04-27-2009 03:18:17 PM
Rule to Calculate Horsepower Stanley Bessent Antique Engine Archives 20 11-21-2001 01:43:14 AM
