Wisconsin Engines
wisconson A E H stromberg carb. rebuild kit
this thread has 12 replies and has been viewed 3690 times
Old 01-13-2014, 09:09:07 PM
DaleBieker DaleBieker is offline
Default wisconson A E H stromberg carb. rebuild kit
hi need to fine a rebuild carb. kit for my AEH eng. with a Stromberg carb. #L45B 2 just got this eng. and saw last week will try run with old gaskits but you know how will that works hope someone can help me out there thanks dale
Old 01-14-2014, 08:21:01 AM
edward moller edward moller is offline
Default Re: wisconson A E H stromberg carb. rebuild kit
good day, go to tractor supply, they a stromberg kit for a massy ferguson tractor. same kit
The Following User Says Thank You to edward moller For This Post:
Old 01-14-2014, 09:37:10 PM
K-Tron K-Tron is offline
I would contact Tim Stine of Rock Creek Consulting. He likely has the exact carburetor kit you need. 1-814-766-3675
Chris
The Following User Says Thank You to K-Tron For This Post:
Old 01-15-2014, 02:15:09 PM
KenHilliard KenHilliard is offline
I checked Tractor Supply and that location did not a ur 3/4 kit. Which massey tractor are you talking about? Also, Rock Creek Consulting only has the bowl gasket, but that most often is the only gasket you need to replace. What I need is the internal gasket for the main idle adjusting jet that was used for the ur 3/4 prior to the later non-adjustable main jet.
The Following User Says Thank You to KenHilliard For This Post:
Old 02-08-2014, 03:16:27 PM
The carb shop has rebuild kits for about $125 that they probably have made from strombergs for flextrac engines..
Old 02-08-2014, 06:59:03 PM
mmcdonald mmcdonald is offline
Support your sponsors. That's all I can say.
info@mcdonaldcarb.com
Old 02-09-2014, 01:21:09 AM
They have the ur carb. The uc carb was on later models and more readily available. Rockcreek has the bowl gasket for the ur and uc models.
Old 02-09-2014, 05:36:23 PM
Like this or am I totally confused
ID:	187401   Click image for larger version
Old 02-19-2014, 03:40:56 PM
At your site you only show the uc carb. This thumbnail is a ur but a uc bowl gasket does not fit a ur and the rest of your parts are questionable for a ur.
---------- Post added at 02:19 PM ---------- Previous post was at 02:14 PM ----------
the big question would be to what extent ur and uc parts are interchangeable? the bowl, float parts and bowl gasket clearly aren't the same. The intake diameter is different. What about the main idle needle? The ur had an adjustable main idle and a fixed main idle.
---------- Post added at 02:40 PM ---------- Previous post was at 02:19 PM ----------
This sponsor has a fine price for the most common AEH carb rebuild kit.
Old 02-19-2014, 07:01:02 PM
Idle needle and spring are same. Nozzle is similar but accelerating holes are particular to carb #. Pretty sure load adjustment will interchange. That's all I remember off the top of my head but there might be a piece or two more.
Old 03-09-2014, 04:03:33 PM
thanks everyone for the help. got carb. and eng. kit from one of the supporters of this sight. have ran eng. but gears are tight with thin gasket will install new oil pan gasket this week eng. seems to run good . clean and adj. clutch . will mount buzz saw soon Dale
Old 09-15-2019, 07:20:32 PM
Bjones Bjones is offline
Dale Bieber, where did you find the carb kit for your AEH engine with Stronberg L45B2 carb? I need the same kit. Mainly needle and seat and gaskets.
Bob Jones
Old 09-16-2019, 09:10:04 PM
Dodd Dodd is offline
Check with McDonald carb and Ignition. They're on the sponsor's page. If it's not listed on the website, call them. That's where I got a kit for my AEH.
Stromberg UC 3/4 carb kit Sonny Ehli Wisconsin Engines 7 11-29-2010 05:56:35 PM
Stromberg UR-3/4 carb kit BruceG Antique Farm Tractors 4 10-25-2008 12:30:32 AM
Stromberg carb kit Sky Hit & Miss Gas Engine Discussion 4 10-24-2007 05:25:33 PM
Need help with Stromberg Carb David Swa nson Antique Engine Archives 2 08-02-2003 08:39:45 AM
