Battery and charging indicator
this thread has 4 replies and has been viewed 1200 times
Old 03-23-2014, 11:34:48 AM
Default Battery and charging indicator
I picked up one of these LED indicator lamps for the Generator. It's a neat affair that lets you see the charging circuity status at a glance.
It's an easy two wire hookup and has some intelligence built into it. Check the website and look at the functionality.
http://www.sparkbright.co.uk/
Old 03-23-2014, 04:41:16 PM
Nazrat Nazrat is offline
Default Re: Battery and charging indicator
That is something that I'd love to have in a little bit larger size. It would be great to have three lights that I could see in the daylight from about 15' away (my closest window): The two phases and the voltage. Then I could easily look out and see if the charger has died, as well as the status of it when it is running.
-Tad
Old 03-23-2014, 04:56:33 PM
len k len k is offline
Nice but in an outdoor shed with no heat you might be better off with a digital numeric reading, to really see what's going on. Bat voltage varies with temp. Would be nice if the LED indicator of a good bat is temp compensated, don't know if this one is.
Just learned all this when rebuilding my Chev alternator. Link to charging voltage vs temp. http://www.tekrispower.com/pdfs/xant...20Charging.pdf
This link is for gel-cells, but car bats behave similarly, maybe curve is shifted by .1-.2 volt.
Old 03-23-2014, 06:05:40 PM
PnishrPW PnishrPW is offline
Actually, it covers wet cells too.
Old 03-23-2014, 11:00:00 PM
Jim McIntyre's Avatar
Originally Posted by len k View Post
...you might be better off with a digital numeric reading, to really see what's going on. ...
Agreed. Little Chinese DVMs are pretty inexpensive these days...
http://www.ebay.com/itm/380793795951...84.m1497.l2649
Onan 4.0 CCK dis-charging battery Eric Schultz Onan Generators 2 04-02-2013 12:16:59 PM
Onan BFA - How do I know the battery is charging? hcfarm Onan Generators 16 06-22-2010 06:07:50 AM
2.5 LK battery charging problem Jim Kinler Onan Generators 2 11-24-2007 03:40:37 PM
Battery Charging AndyG Trucks, Trailers and Hauling for Shows 10 09-25-2005 04:27:33 PM
6.5NH Battery Charging shawnb Onan Generators 2 12-11-2004 10:08:10 PM
