Oil Field Engines
25hp Superior
this thread has 6 replies and has been viewed 1528 times
Old 03-01-2016, 05:17:12 PM
JWithers JWithers is offline
Default 25hp Superior
Working on a 25hp 4 cycle Superior. Trying to get the covers off the exhaust valve cage but the covers and studs are rusted together. Can anyone tell me if this cover is flat across like the intake valve cage cover or does any of it extend down into the cage at all?
ID:	247858   Click image for larger version
Jeremy Withers
The Following User Says Thank You to JWithers For This Post:
Old 03-01-2016, 06:57:26 PM
Leonard Fausset's Avatar
Leonard Fausset Leonard Fausset is offline
Default Re: 25hp Superior
All that i have seen are flat.
The Following User Says Thank You to Leonard Fausset For This Post:
Old 03-01-2016, 08:58:42 PM
machine and fab machine and fab is offline
The cover on mine has a round tapered feature that extends into the valve box about a half an inch. This tapered seat feature creates a seal which is why you don't see a gasket.
The Following User Says Thank You to machine and fab For This Post:
Old 03-01-2016, 10:28:41 PM
I could be wrong, but I think there is a gasket. I've been trying to scrape something from what I think is a seam. Iron is pretty rotten in the area.
---------- Post added at 08:28:41 PM ---------- Previous post was at 08:26:38 PM ----------
Might have to take the valve cage off to try to tap it off from the inside.
Jeremy Withers
Old 03-02-2016, 12:14:49 AM
JSWithers JSWithers is offline
Is this your engine now Jeremy or are you working on it for Keven?
Old 03-02-2016, 12:36:13 AM
Can't afford to work on my own right now so I'm getting my fix by working on it for/with Keven.
Believe me if it was mine now you would have gotten a pretty excited text from me!
Jeremy Withers
Old 03-08-2016, 09:44:26 PM
Made a little progress today on the valve cage. Was able to get the front cover off. Inside looks pretty good except that the top two stud holes are packed with rust, the bottom were almost clean. After a good while attempting to bust it loose the decision was made to saw the top studs off. Ran out of hack saw blades.
ID:	248424   Click image for larger version
ID:	248425   Click image for larger version
ID:	248426   Click image for larger version
Jeremy Withers
The Following 3 Users Say Thank You to JWithers For This Post:
25hp Superior Mark Mohney Oil Field Engines & Related Equipment 3 06-27-2012 10:43:41 PM
25hp Superior Harold Price Oil Field Engines & Related Equipment 7 02-01-2011 01:38:35 PM
25hp Superior moparguy Oil Field Engines & Related Equipment 3 11-28-2010 05:23:47 PM
25hp Superior Tom Weatherford Oil Field Engines & Related Equipment 1 10-24-2010 10:15:29 PM
Superior 25hp fixer1952 Hit & Miss Gas Engine Discussion 10 07-28-2008 07:21:09 PM
