Wisconsin Engines
Wisconsin AC4-I First Start
this thread has 8 replies and has been viewed 1625 times
Old 09-09-2016, 08:56:08 PM
farlander762 farlander762 is offline
Default Wisconsin AC4-I First Start
Hello,
This is my first post to this forum. I picked this up from my grandfather's estate. I think everyone else in the family either forgot about it or didn't know what it was to start with. As I recall, my grandfather told me that they used it to start a big hit-or-miss engine, big enough that it took a ladder to hold the exhaust valve(s) open for startup. He would have used it somewhere near Roby, TX.
I will be placing it for sale once I know what it's worth.
https://youtu.be/nniy9Pvy78M
Here's what I know:
Manufactured in January 1943 (searched s/n).
Wisconsin optional clutch (works).
Purchased by Army Air Corps (later USAF), no idea what they used it for.
Overhauled in March 1953 (it has a second nameplate on it).
Integral ignition system with manual spark advance (no magneto).
Stromberg R-3/4 right-angle carburetor (only one I've ever seen).
Electric start.
Generator electrical with voltage regulator disconnected.
Only one I've seen in this housing.
I have all of the shrouds and covers.
Had two bad ignition cables so I replaced them with the first thing that came to hand, trailer wire (white, brown, green, yellow)! Hey, it worked.
The spark advance cable is rusted solid.
Here's what I did to make it run:
Replace the ignition coil.
New cranking battery, not a golf cart deep cycle.
Replace the + lead from the switch to the coil (dang rats).
Bypass the fuel pump and add an OMC (Evinrude/Johnson) fuel connector. I will be taking it back off before I sell the rig.
Lubricate the tachometer cable.
Oiled the valves before attempting starting.
Oiled pretty much every moving thing I could get to.
Cleaned a huge dirt dobber nest from the starter.
Disassembled and inspected the carburetor.
Put the choke, throttle, and spark cables in an industrial ultrasonic cleaner for about 3 hours. Still didn't help the spark cable.
Changed the oil. Castrol straight 30W.
A few other minor points.
Pictures were taken while I was working on it so it is in some state of disassembly.
PLEASE LET ME KNOW WHAT YOU THINK! I WILL ALSO ANSWER ANY QUESTIONS I CAN!!!
Lance
ID:	262497   Click image for larger version
ID:	262498   Click image for larger version
ID:	262499   Click image for larger version
The Following User Says Thank You to farlander762 For This Post:
Old 09-09-2016, 09:10:41 PM
Zira Zira is offline
Default Re: Wisconsin AC4-I First Start
Neat engine! The dog house doesn't look too different from most. I am guessing it ran after what you did to it? I would try to replace the trailer wire ASAP but the rest seems logical.
Old 09-09-2016, 09:26:18 PM
Oh yeah! Runs great. I really don't want to spend any more on it. Just wanted proof of life. The YouTube video shows my first start.
I forgot to mention that I also have a factory printed manual for it. Not a copy or scan.
Old 09-09-2016, 10:46:34 PM
Vanman Vanman is offline
Wow, sounds nice. Sounded like it stopped rather abruptly at the end. Still, likely worth more than a couple hundred bucks I'd think, so that exceeds my supply of play money.
Old 09-10-2016, 08:41:00 AM
My wife stopped the video rather abruptly. The smoke smell from the mixed gas was getting to her. She has a sinus infection right now.
A couple more pictures. My helper cat...
ID:	262525   Click image for larger version
Old 09-10-2016, 02:15:25 PM
Ah, I see. Well, it looks like someone is enjoying being up close and personal with the engine. And will keep the rats away.
Old 09-10-2016, 08:42:44 PM
David A. David A. is offline
let me know what u asking for it, thanks
Old 09-10-2016, 11:39:24 PM
Terry Hammer Terry Hammer is offline
Its a good thing it has electric start! Hand cranking would of wore you out!The motor sounded great!Sure would like to see a Ariens Model A rototiller run with the old AC 4!
Old 06-19-2019, 12:48:55 PM
boone007 boone007 is offline
I could use a copy of manual if possible thanks dan !`
Wisconsin TJD No Start ZZTrencher Wisconsin Engines 6 03-15-2016 03:51:42 PM
Hard to start Wisconsin pond1954 Garden Tractors and Mowers 3 08-06-2012 12:04:28 PM
Wisconsin TJD Won't Start budro Wisconsin Engines 10 09-30-2010 08:49:36 PM
How do I Start A Wisconsin VE4 nutsnbolts24 Hit & Miss Gas Engine Discussion 6 08-14-2010 11:57:54 PM
wisconsin VF4 won't start chuck cleveland Generators & Electric Motors General Discussion 6 11-01-2003 01:14:54 PM
