Wisconsin Engines
Wisconsin AC4 engine looking for gaskets
this thread has 7 replies and has been viewed 1263 times
Old 02-24-2017, 07:54:23 PM
blacktinlizzie blacktinlizzie is offline
Default Wisconsin AC4 engine looking for gaskets
Picked up this engine to mount on a tractor project. It looked very complete
I will be going thru it to get it running today got spark but could only get it to pop every so offen.
Is there a source for gaskets for this engine in case I need to break it open
I have included photos to help identfy it
ID:	275806   Click image for larger version
ID:	275807   Click image for larger version
ID:	275808   Click image for larger version
The Following User Says Thank You to blacktinlizzie For This Post:
Old 02-24-2017, 09:48:18 PM
K-Tron K-Tron is offline
Default Re: Wisconsin AC4 engine looking for gaskets
Wow, very nice AC-4! Although your engine looks complete, the carburetor and air cleaner are off a Briggs & Stratton, likely a Model Z or ZZ. The AC-4's used a Stromberg UR 3/4" cast iron carburetor, and used an oil bath air cleaner (mounted outside of the power unit) like you would find on a THD/TJD. Looks like you will also need a new blower screen (Wisconsin SE-20-B). That can be made with ease out of expanded steel. Im sure the entire screen interchanges with something off maybe an AHH or a VE4...The original muffler is missing, those cast iron trumpet mufflers are about impossible to find. Tim Stine likely has some parts for these engines. The AC-4, like its big brothers the AM-4 and AP-4 are overhead valve engines, they are a bit different than the more common flathead Wisconsin engines that everyone is more familiar with. I have an operators manual, service manual, and an illustrated parts list for the AC4, if you need any information let me know,
The AC-4 makes 16 horsepower at 2600rpm, and produces a maximum of 39.5 lb/ft torque at 1600rpm. I think it will make a very unique power plant when its ready to use.
Chris
The Following 2 Users Say Thank You to K-Tron For This Post:
Old 02-25-2017, 10:49:23 AM
Thank you for the reply I was happy it had all the sheet metal most engines I have seen are missing at least one cover Going to do a leak down test then go from there Bill
Old 02-25-2017, 03:18:51 PM
Doug Tallman Doug Tallman is offline
I noticed the cover on the carb side of the engine in pic 4. Don't think I've ever seen that before. If I did, it must not have stuck out. I can understand keeping hot air away from the carb but where did they expect it to go? Seems like it would trap the heat.
Old 02-25-2017, 07:32:37 PM
Might act as a hot air pipe to the intake manifold
Seems to direct hot air at intake and away from carb.
Bill
Old 02-27-2017, 10:16:43 AM
ti-jean ti-jean is offline
here you will find everything for Wisconsin and all
http://www.marind.ca/fr/produits_ind...iel/index.html
Old 07-12-2019, 01:59:34 PM
boone007 boone007 is offline
I have asset to some gaskets & have extra block new carb thanks dan
Old 07-12-2019, 07:14:34 PM
Angus II Angus II is offline
^^^^^ scammer alert......
Wisconsin VG4D Intake manifold gaskets. sailersteve Wisconsin Engines 4 12-29-2015 10:40:10 PM
Diamond engine new old stock gaskets Bryce D Antique Autos and Trucks 2 03-08-2015 12:18:45 AM
Wisconsin Gaskets NOS Q34A, Q35B,Q29,Q22 LandLFarm Wisconsin Engines 10 12-21-2013 08:32:29 PM
Wisconsin UA gaskets and Stromberg carb M-2 dunefanatic Antique Farm Tractors 5 02-05-2010 10:26:00 AM
Wisconsin s-12d gaskets and seals... ataboy9026 Hit & Miss Gas Engine Discussion 1 09-03-2009 01:08:20 AM
