6 Cylinder Flat Head ID
this thread has 12 replies and has been viewed 1383 times
Old 03-19-2018, 09:08:10 PM
Paul Johnson Paul Johnson is offline
Default 6 Cylinder Flat Head ID
Engine #9F-126480
Head casting #8FA627A
Not for sale, shop art bragging rights
Thank you, Paul
ID:	306010   Click image for larger version
ID:	306011   Click image for larger version
ID:	306012   Click image for larger version
Old 03-19-2018, 09:57:52 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Default Re: 6 cyl flat head ID
You gonna put that into the old Chevy pickup?
Old 03-19-2018, 10:50:33 PM
Heins Heins is offline
What does the engine tag say?
Old 03-20-2018, 06:32:23 AM
Elden DuRand's Avatar
Default Re: 6 Cylinder Flat Head ID
It could possibly be Willys-Overland or Whippet.
The Whippet was available in both a 4 cylinder and and a six. The four had a timing chain driven generator and the distributor was driven off the end of the generator.
Then, I could be wrong.
[SIGPIC][/SIGPIC]
Take care - Elden
http://www.eldensengines.com
Old 03-20-2018, 10:04:50 AM
More info. Tag has ser # and patent #s. Cast in the head are each cyl
and the date 1-20-28. Frank; I may fudge some but flat head 6 in a Chevy It will be back in NDak in July, fresh paint and no rust.
The Following User Says Thank You to Paul Johnson For This Post:
Old 03-20-2018, 05:51:38 PM
Ref Tag 4 this 6 has distributor drive off generator.
Only patent dates latest Feb 1/21.
Couple of old time re builders are thinking Continental but fudging a bit,
Pontiac ? and gm product
Old 03-20-2018, 09:10:40 PM
gootsch gootsch is offline
Chevys of that vintage were overhead valve engines.
Old 03-21-2018, 07:56:18 AM
BHoward BHoward is offline
Pontiac in the 20s had 2 heads.
Old 03-21-2018, 12:46:26 PM
Greg Mosley Greg Mosley is offline
Greetings, Could it be a Hudson??? Enuf Said
Old 03-27-2018, 10:22:02 PM
Question Re: 6 Cylinder Flat Head ID
A little brushing; cast on the corner of the head is C over L, any clues?
Old 03-27-2018, 10:26:35 PM
Craig Gillingham Craig Gillingham is offline
Sometimes the make and model of starter and generator tags can narrow down what it is. The starter looks like a Delco-Remy, which are very well documented.
Old 03-27-2018, 11:02:26 PM
FWurth's Avatar
One Millionth Post
Isn't that marking on early Dodge engines?
Old 03-28-2018, 01:50:31 AM
Depends what you call early Frank.
Before 1926 Dodge engines used a starter/generator and after that the separate starter and generator are on the opposite side of the engine shown in the photo.......
Old 4 cylinder flat head on Marble Gen clancy1010 Unidentified Engines 3 09-03-2010 10:02:47 PM
Flat head Continental Brian.P Antique Farm Tractors 11 11-11-2009 04:59:47 PM
CONTINENTAL Red Seal 4 cylinder flat head engine treecutter00 Antique Farm Tractors 6 01-24-2009 02:55:51 AM
flat head Wade Kimball Antique Engine Archives 4 06-01-2000 11:00:31 PM
