Camshaft timing marks 1922/28 4 cyl chevy
this thread has 6 replies and has been viewed 537 times
Old 10-08-2018, 02:13:46 PM
Rod Gaffrey Rod Gaffrey is offline
Default Camshaft timing marks 1922/28 4 cyl chevy
I need to find a Guru with experience setting the camshaft to crankshaft timing marks on the early 4 cyl chevy motors.
The book show's when the timing marks on the camshaft and the crank shaft are lined up, there should be 14 teeth between crankshaft timing mark and the centerline of the keyway on the camshaft.
I have three gears here that have 15 teeth between camshaft/keyway centerline and the camshaft timing mark.
What am I missing?
Old 10-08-2018, 06:58:55 PM
Jack Innes's Avatar
Jack Innes Jack Innes is offline
Default Re: Camshaft timing marks 1922/28 4 cyl chevy
Could it be that the tooth that is lined up with the mark is not considered "between" the mark & keyway?
Old 10-08-2018, 07:08:08 PM
Set it where you think it should be, place the lifters on the #1 cylinder lobes. When the piston moves from top center either way, one lifter or the other should move if your not on the firing stroke, if nothing happens turn it one round and try it. It's obvious when it's correct.
Old 10-09-2018, 06:56:26 AM
Phil P Phil P is offline
Hi
This is the way I check all of my camshaft installations regardless of the marks.
Phil P
The Following User Says Thank You to Phil P For This Post:
Old 10-09-2018, 08:25:52 AM
BHoward BHoward is offline
Do what he said.
The Following User Says Thank You to BHoward For This Post:
Old 10-09-2018, 10:42:58 AM
Thanks.
I had it set fourteen teeth apart and will leave it there.
Makes one wonder how many early Chevys are running around with the camshaft retarded one tooth.
Old 10-22-2018, 11:49:33 AM
edisondiamond edisondiamond is offline
Vintage Chevrolet Club of America site;
https://vccachat.org/
Some areas are open, like the teck section, others are closed.
John Deere 46 A Camshaft timing marks SlantdashA Antique Farm Tractors 4 01-19-2013 11:29:32 AM
1922 large tag IHC M,1.5 horsepower,timing marks mopar44032b Hit & Miss Gas Engine Discussion 0 06-04-2012 12:59:51 PM
Timing Onan 4.0CCK Can't see timing marks? Magnetite Onan Generators 2 04-02-2012 11:30:15 AM
Timing marks shmiming marks... 2HP FM H Video Jim Sherman Hit & Miss Gas Engine Discussion 1 11-28-2010 07:12:46 PM
FMZ Camshaft Timing? Bill Blackburn Antique Engine Archives 3 10-23-2002 12:11:51 PM
