Wire Wound Resistors
this thread has 2 replies and has been viewed 482 times
Old 10-22-2018, 01:54:14 PM
Question Wire Wound Resistors
I am currently working on several American La-France 700 series fire trucks, with the V-12 engines. My problem is that both trucks have the same problem. Mice have chewed the wire wound resisters that provide power to the instruments. Gas guage, fuel guage and oil pressure guage. The trucks use 12 Volts. I have been told that the resister resistance value id 37.5 ohms, but I do not know at what current level I need. Also, who might have resisters of that value? I don't want to provide too much power to the senders, especially the fuel tank! Can anyone help with this? I was thinking of a variable potentiometer, but don't know the current or heat made by the pots will burn them out, under the load of the instruments. I am not sure if the gauges are of the King-Seeley or Stewart type either, only that with the resisters chewed up, there are no readings. We are trying to keep the original gauges, as they are in the instrument cluster on the dash.
Thanks, Andrew
Old 10-22-2018, 02:37:53 PM
Horse Power at 511's Avatar
Horse Power at 511 Horse Power at 511 is offline
Default Re: Wire wound resisters
Hey Andy! It was good to see you at Jacktown!
I think you should get set up with a good DC power supply measuring output voltage and current. Isolate one gauge and sender combo at a time and slowly bring the supply voltage up from zero until the gauge reads properly, be it fuel level, oil press or temp. From the current meter reading you can calculate what your resistor rating needs to be with 12v applied to the circuit when it is connected on the truck.
The Following 2 Users Say Thank You to Horse Power at 511 For This Post:
Old 10-22-2018, 07:33:50 PM
radiodoc radiodoc is offline
Default Re: Wire Wound Resistors
Andrew if the resistance is supposed to be 37.5 Ohms you could get yourself a couple 75 Ohm 5 or 10 Watt wirewound resistors and put in parallel and I am pretty sure (not positive though) that would carry the gauges. Mouser or DigiKey and other places have wirewound resistors. You should have the equivalent of a 10 or 20 Watt resistor. Allie
The Following 2 Users Say Thank You to radiodoc For This Post:
Limiting Resistors Railroads Generators & Electric Motors General Discussion 44 08-08-2015 04:17:07 PM
Onan Charging Resistors Viking66 Onan Generators 52 04-30-2014 12:27:28 PM
Onan BGA wire wound Battery charge resistor jdegen Onan Generators 5 09-01-2013 08:46:59 PM
Onan DEH/15R RESISTORS TCSelectric Onan Generators 7 05-23-2007 01:13:47 PM
Wire Wound Resistor Replacement? Mike Cushway Kohler Generators 17 01-26-2007 12:44:24 PM
