Smokstak Down Under
Mascon double action piston pump
this thread has 36 replies and has been viewed 2413 times
Old 07-22-2019, 01:29:52 AM
Jaybear Jaybear is offline
Default Re: Mascon double action piston pump
Thanks Scott
The plate is loose in there but I cannot turn it at all
Would you be able to tell me how much I need to turn it and which way?
Old 07-22-2019, 02:09:00 AM
Scotty 2 Scotty 2 is offline
Originally Posted by Jaybear View Post
Thanks Scott
Not yet.
The Following User Says Thank You to Scotty 2 For This Post:
  #23
Old 07-22-2019, 03:46:16 AM
Thanks Scott
Are you sure we have the same pump because the plate is loose sitting there but it will not turn????? I’ve even put bolts in two corners and put a bar between them to try to turn it?????
This is a macson style B and that’s the only plate on the pump with information.
Old 07-22-2019, 05:50:28 AM
holkim holkim is offline
I was always under the impression that Macson's were abbreviated trademark of and made by McPherson and Son.
They made Macson's with bronze/brass bush's and later on in the 30's when they released Ajax pumps they had ball bearings or similar. ????
Picture of my 4 x5 Macson and 2-1/2 x 4 Billabong pumps
The Following 3 Users Say Thank You to holkim For This Post:
  #25
Old 07-22-2019, 04:23:42 PM
Hello all
According to picture you turn the stuffing box anti-clockwise to withdraw it without the liner and the liner pulls straight out.
I can't see why yours would be different to the model the tag is on......but in saying that, it may be different.
I might get a chance this afternoon to have a play, but this week is hectic.
Cheers Scott
  #26
Old 07-22-2019, 04:52:39 PM
Paul Richardson Paul Richardson is offline
Mine came out ok Jaybear,but i made sure that the stuffing box was not grabbing the plunger shaft etc.
You need to be certain that there's nothing else gripping it.
From there i do recall that mine was quite stubborn,taking quite a bit of elbow grease,and a good few floodings with my kerosine squirt bottle along the way.
The Following User Says Thank You to Paul Richardson For This Post:
  #27
Old 07-22-2019, 06:01:05 PM
Thanks Scott and Paul
I drowned it in CRC and oil yesterday so I will give it another go tomorrow. I have managed to get the plunger rod out with a shifter through one of the bottom holes so it can’t be the that. Anyway I’ll give it a go this arvo thanks for your help
Old 07-29-2019, 03:25:51 AM
Hello Mr Bear.
As mentioned.....turn the big square plate anti-clockwise to remove the plate or straight out to simply remove the liner/plate.
I finally got 37 seconds of spare time to take the plate off our pump. The pictures may help.
Cheers Scott
This one will let you gauge how much twist the big square plate to pull the only the big square plate
It may be hard to see but this one shows a little cast pin which slots into the slot in the liner. There are two pins and two slots overall.
The Following 3 Users Say Thank You to Scotty 2 For This Post:
  #29
Old 07-30-2019, 06:15:20 PM
Thanks you so much Scott
This will help a lot I will try again this arvo I’m having no luck so far. Dad is suggesting we put a bit of heat to it to try to free it up a bit..... do you have any other suggestions to get it to turn?
Old 07-31-2019, 02:45:55 AM
cobbadog cobbadog is offline
Squirt it with Lanox or similar even some diesel.
Old 07-31-2019, 06:20:01 AM
As recommended above by Cobba Jaybear,..diesel,kero,heating oil,..any of those instead of, or even in addition to your favourite penetrant.
I would recommend drowning any of the problem area and backing off the moisture level from there.Keep wiggling and working the stubborn part by hand while giving it plenty of drenchings in between.The theory being with a part that is 'moving',that your working it 'to and fro' coupled with a continued dousing with the fuel oil,diesel etc,gives it a chance to clear particles from between the contacting surfaces.
Scotties internal view reminds me of my own pump,which had plenty of rust growth around the locking mechanism of the front plate as well.Mine was quite stubborn to remove as well from memory?
It might not happen tomorrow,or the next day,but persistence should get you there?
  #32
Old 08-02-2019, 07:23:18 PM
Hey Guys, I FINALLY GOT IT OUT!!!
Turns out you were wrong there is no key way on this pump..... it must be different? We had to heat up the pump and pull the liner out I’ll send you photos now my next problem if anyone knows how do I knock the pin out holding the cap to the liner? Thank you for all your help and advice
Old 08-02-2019, 08:04:26 PM
The Following 3 Users Say Thank You to Jaybear For This Post:
  #34
Old 08-03-2019, 01:38:09 AM
I know nothing about these pumps or how to rip them apart but going by your pic it is not a pin it looks more like a screw head. If this is the case start soaking it with all the oils etc and then use some of that heat on it to help it undo.
Having said that, wait until someone who does know about these pumps gives you the heads up.
  #35
Old 08-03-2019, 03:04:52 AM
Jaybear.......one thing i took for granted here was your level of experience unsticking old machinery.Looking at your first pic above i am reminded of my first hard lesson first hand,about the 'biscuit brittle' nature of cast iron.
I'm wondering have you got a similar story to tell us about the front plate?
I agree with Cobba on the nature of the pin,being most likely a shank style screw with no head and just a slot?
That might take some moving,but going along with Cobba once again.I think a number of warmings and soakings over a period of time would eventually see you win out?
  #36
Old 08-03-2019, 03:51:45 AM
Hello Mr Bear.
You've done very well. At least now you can get rid of the rust that hides behind the liner. A lot better job then what I'll probably end up doing. The liner will have to fall out for me to worry about it.
Now we need to go back a few posts.
Originally Posted by Scotty 2 View Post
At a guess: that square plate is how the liner comes out. There may be 2 tags on the other side of the plate which has a screw or two attaching it to the liner so when the plate comes out, so does the liner.
Sound feasible?
Not a bad guess huh?
Cheers Scott
Old 08-04-2019, 11:10:21 PM
Thanks guys they were threaded, a bit of heat and some vide grips got em out. Yes Paul I did know cast was very brittle, I’ve been studying how to weld it up hopefully it turns out all good but i was not the one who broke every corner off of the plate my old man decided hammers and pry bars were the way to go. XD thanks you all so much for your help I will definitely post a video on this page of it being run by my CS lister. Cheers
The Following User Says Thank You to Jaybear For This Post:
The refit of a double piston steam engine Arona2019 Scale Model Engineering 0 04-22-2019 08:10:26 AM
Water pumps. Differences between single & double action? Scotty 2 Smokstak Down Under 77 12-15-2016 03:21:14 PM
Goulds double action hand pump ronny p 148 Farm Antiques and Collectibles 6 08-12-2016 11:19:33 AM
piston size for double expansion?? Dale Weaver Steam Stationary Engines, Traction Engines 11 06-30-2015 01:22:05 PM
Myers or Goulds double-acting piston pump Jeff Wahl Farm Antiques and Collectibles 6 04-24-2014 08:29:43 AM
