Welding Shop
Marquette 501 UL ?
this thread has 3 replies and has been viewed 4806 times
Old 02-13-2009, 03:43:57 PM
kilysa kilysa is offline
Photo Marquette 501 UL ?
I recently got a OLD marquette AC arc welder I was hopeing someone could help me find the worth
Model # 501 UL
Serial # 103491
primary volts- 230
primary amperes- 37
secondary amperes- 180 MAX
open circuit voltage- 80 MAX
cycles-60
phases-1
secondary volts-25
rated duty cycle-20%
I have no year for it
ID:	48623   Click image for larger version
Old 02-13-2009, 08:51:22 PM
Delco 32 Volt Delco 32 Volt is offline
Thumbs up Re: marquette 501 UL ?
I don't know the year,but I use one just like it almost every day.Very good machine!Just. don't try to lift it.Lots of copper in the windings. Steve
Old 03-21-2009, 06:33:23 AM
NodRemark NodRemark is offline
Default Re: Marquette 501 UL ?
I contacted Lincoln Electric and they told me the 501 was built during the late 50's to the early 60's. They emailed me a pdf file copy of the owners manual. I paid $70 for mine a few weeks ago. I did a little cleaning and had to change out the male cap on the electric feed to meet current 50AMP code. I plugged it in and it purrs like a kitten. Nice machine IMHO.
Old 05-22-2019, 05:22:56 PM
andersrick andersrick is offline
Your original response----I contacted Lincoln Electric and they told me the 501 was built during the late 50's to the early 60's. They emailed me a pdf file copy of the owners manual.
Hi, I know some time has past since you posted this response on the Marquette Arc Welder manual. I just obtained the same model, works great but I would like to find a manual. i did try Lincoln Electric, but they were no help to me. Do you still have the manual you were able to obtain? Would you be willing to share it?
Marquette Generator/Welder help slime Welding Shop 1 10-28-2014 10:27:52 AM
Marquette red rod 30 Rob Charles Welding Shop 1 01-21-2013 12:08:33 PM
Marquette 60C Farm Welder rexmo Welding Shop 0 07-31-2012 09:36:35 AM
Marquette Gen M-71-2657 chamokie Kohler Generators 6 11-25-2010 08:22:20 PM
Marquette 220 Welder johnny45 Welding Shop 2 12-06-2006 08:20:36 AM
