Unknown Carburetor
this thread has 5 replies and has been viewed 520 times
Old 05-22-2019, 03:28:34 PM
oldsoldster oldsoldster is offline
Default Unknown Carburetor
I acquired this carb with a couple of curved dash Olds engines. It has a threaded hole drilled through the name but may be "Gray Motor Co " . Thread size is 1 1/4 inch. The float bowl also has two different sized threaded holes in the bottom. I'm thinking it's likely a stationary engine carb.Anyone recognize it ?
Jim
ID:	335370   Click image for larger version
The Following 2 Users Say Thank You to oldsoldster For This Post:
Old 05-22-2019, 03:46:21 PM
Default Re: Unknown Carburetor
I would say that came from a Gray inboard marine engine?
Old 05-22-2019, 05:11:00 PM
You could be correct. Looks similar to one in an ad for a one cylinder Gray.
The Following User Says Thank You to oldsoldster For This Post:
Old 05-22-2019, 05:21:38 PM
www.oldmarineengine.com
Old 05-22-2019, 05:52:03 PM
Bingo ! Scrolling down through the Gray section of the "oldmarineengine.com" website, it seems to be for a Model R Gray ca.1908.
Apparently this was the only year they supplied their own carb.
Old 05-22-2019, 06:15:57 PM
Later carbs were a Schebler
Unknown Carburetor MiqC2001 Carburetors, Mixers, Fuel Pumps and fuel delivery 2 09-09-2018 08:54:10 PM
ID Unknown Carburetor? G.M.Johnson Small Air Cooled Gasoline Engines 6 02-08-2017 07:19:12 PM
unknown carburetor mokeabean Carburetors, Mixers, Fuel Pumps and fuel delivery 3 11-26-2014 05:49:49 PM
Unknown Carburetor Wayne Timms Carburetors, Mixers, Fuel Pumps and fuel delivery 0 02-07-2014 10:30:48 PM
Unknown Carburetor Keven Withers Hit & Miss Gas Engine Discussion 2 02-14-2009 07:52:50 PM
