Wisconsin Engines
Wisconsin S-12D Dipstick
this thread has 3 replies and has been viewed 478 times
Old 06-01-2019, 09:00:35 PM
Family Tradition Family Tradition is offline
Default Wisconsin S-12D Dipstick
I purchased a Lindsay air compressor recently. It’s powered by a S-12D. I got it running nicely and it makes a lot of air but the dipstick is missing. Has the original cap but no rod. Can anyone tell me the length it should be or where I could get one?
Old 06-02-2019, 12:57:25 PM
CharlieB CharlieB is offline
Default Re: Wisconsin S-12D Dipstick
Just checked my S-12D for you.
The dipstick is a rod extending from a standard pipe plug threaded into the top of the crankcase casting.
The overall length of the rod is 7 5/8" from the bottom of the plug.
There is a groove marking the high oil level at 7 1/8" from the bottom of the plug. When tightened, the plug extends 3/8" below the surface of the casting. Depending on the spec. number or your engine, the dipstick arrangement may be different, but the above numbers will establish the correct oil level.
The Following 2 Users Say Thank You to CharlieB For This Post:
Old 06-02-2019, 07:00:00 PM
Much appreciated Charlie
Old 06-02-2019, 07:56:05 PM
Thumbs up Re: Wisconsin S-12D Dipstick
Glad to help.
Wisconsin THD Dipstick Larry Evans Wisconsin Engines 5 09-14-2018 12:05:38 PM
Dipstick 160 Welder Ted Godzisz Welding Shop 3 01-06-2010 10:55:07 PM
FBM Z engine w/o dipstick Stevie Antique Engine Archives 2 11-05-2002 12:38:28 AM
