Wisconsin Engines
VH4D hp Ratings
this thread has 4 replies and has been viewed 311 times
Old 07-03-2019, 08:22:12 PM
Tracy T Tracy T is offline
Question VH4D hp Ratings
I have a vh4d, and was currious the horse power @ rpm ratings. it is a fresh rebuild, only modification is a overbore 0.020 if i remember right.
Old 07-03-2019, 10:16:17 PM
K-Tron K-Tron is offline
Default Re: vh4d hp ratings
The Wisconsin VH4D is rated 17.2hp at 1400rpm, 22.5hp @1800rpm, 26.5hp @ 2200rpm, and 30hp @ 2800rpm. They are a real workhorse of an engine, and were very popular in their heyday.
Chris
The Following 2 Users Say Thank You to K-Tron For This Post:
Old 07-04-2019, 01:14:49 PM
thanks, now i have some numbers to work with for gearing. I am going to use this engine to power a welder hopefully.
---------- Post added at 01:14:49 PM ---------- Previous post was at 01:13:43 PM ----------
looking at the numbers again, i may be able to direct drive it!
Old 07-04-2019, 02:39:48 PM
Vanman Vanman is offline
Default Re: VH4D hp Ratings
Yeah, I was thinking it looks ideally suited to direct driving the generator at 1800 rpm. A little reserve HP so the throttle doesn't have to be wide open when welding at the maximum current setting.
Old 07-04-2019, 02:47:59 PM
vanman, see ya back over in the welder section!
The Following User Says Thank You to Tracy T For This Post:
Power washer pump ratings are actally unloaded pressure ratings! K-Tron Small Air Cooled Gasoline Engines 14 04-25-2019 12:56:01 PM
Horsepower Ratings? G Willikers Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 08-19-2018 10:00:02 PM
KVA ratings vs KW ratings Fredfarkle Onan Generators 8 09-08-2010 02:54:55 PM
HP ratings - What do they really mean? GaarScott Steam Stationary Engines, Traction Engines 35 08-08-2007 02:54:46 PM
What does it mean? (Oil Ratings) Michael Studier Garden Tractors and Mowers 7 05-29-2007 12:27:47 AM
