Wisconsin Engines
VH4D Crankshaft
this thread has 3 replies and has been viewed 293 times
Old 07-07-2019, 10:55:08 AM
Mogman Mogman is offline
Default VH4D Crankshaft
I have a VH4D on my JLG lift that is very tired and now the valves are starting to stick, I also have a VH4D that came off of a Case 25+4XP ditcher, what are the chances the crankshaft output dimensions are the same? did Wisconsin make different ones or are they all the same?
Old 07-07-2019, 11:31:08 AM
Default Re: VH4D Crankshaft
They made many different configurations. Ya better check before you dive into it.
Old 07-07-2019, 05:42:10 PM
Mitch Malcolm Mitch Malcolm is online now
Whey back in one of my past jobs I worked on lots of Bobcat skid steers in those days there where only a tapered shaft for a clutch (used on the bobcats) and plain straight shafts . used on most everything else .
Old 07-08-2019, 09:28:27 AM
Tracy T Tracy T is online now
they made machine specific crankshafts as noted, i have a vh4d that came out of a roller the crankshaft was so short i couldnt use it wound up buying one off of flebay for a bobcat. by the way the bobcat crank was a good fit now i can use the engine for what i wanted to.
VH4D hp Ratings Tracy T Wisconsin Engines 4 07-04-2019 02:47:59 PM
Vh4d sprayrigguy Wisconsin Engines 1 04-01-2019 02:15:52 AM
VH4D Crankshaft Gear 2bobcats Wisconsin Engines 13 08-17-2017 08:48:18 PM
VH4D Wisconsin Help!! Firedog413 Wisconsin Engines 5 10-08-2015 05:56:29 PM
Help with a VH4D Bowtiebutler956 Wisconsin Engines 0 02-19-2013 09:36:54 PM
