Smokstak Down Under
Famous vertical governor
this thread has 1 replies and has been viewed 304 times
Old 08-06-2019, 01:41:20 AM
lewman lewman is offline
Email NOT Working
Default Famous vertical governor
Hi out there
I need to repair a governor collar on a 2hp famous vertical I am in need of the over all diameter of the collar and the angle on the collar on which the latch out arm rolls on if that make any sense
Thanks steve
ID:	340863   Click image for larger version
ID:	340864   Click image for larger version
Old 08-06-2019, 02:10:59 AM
cobbadog cobbadog is offline
Default Re: Famous vertical governor
In your second image that it the angle you need to achieve so measure that then build up the original collar and machine it down to that angle. Make a new roller while your at it too.
IHC Famous Vertical 2hp Pascal22 Hit & Miss Gas Engine Discussion 21 07-10-2018 01:31:53 PM
2 HP Vertical Famous ?'s Mike Smith Hit & Miss Gas Engine Discussion 5 05-13-2013 09:26:10 PM
Vertical Famous governor springs Johnny T Hit & Miss Gas Engine Discussion 4 03-08-2008 06:04:41 PM
2hp IHC vertical Famous Johnny T Hit & Miss Gas Engine Discussion 1 12-11-2007 01:06:02 AM
2 hp IHC Vertical Famous Chad Hit & Miss Gas Engine Discussion 2 07-28-2005 08:19:10 PM
