John Deere AR engine trouble
this thread has 23 replies and has been viewed 1592 times
Old 08-11-2019, 07:18:29 PM
Jack Innes's Avatar
Jack Innes Jack Innes is offline
Default John Deere AR engine trouble
I am jumping the gun a bit here; I just committed to buy a mid 40s unstyled JD AR that I have not seen in person. There is an engine problem - it has compression on one cylinder only & it will not turn completely over, there is a clunk when it stops turning. Any suggestions on what to look for? Optimistically I am thinking a dropped valve but it could be worse.
It is unknown if this happened running or not.
I hope to pick it up mid week & will know more then.
Thank you,
Jack
The Following User Says Thank You to Jack Innes For This Post:
Old 08-11-2019, 07:24:45 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Default Re: John Deere AR engine trouble
I'd lift the crank case cover and look for connecting rod issues.
The Following 2 Users Say Thank You to FWurth For This Post:
Old 08-11-2019, 07:33:47 PM
David Hoover David Hoover is online now
Maybe just a stuck valve. Might be a pretty good tractor, just sat to long
The Following 2 Users Say Thank You to David Hoover For This Post:
Old 08-11-2019, 08:24:41 PM
FWurth's Avatar
One Millionth Post
If it makes a sudden hard stop with a genuine clunk sound, it's hitting something that's striking the crank most likely. A stuck valve won't do that, it will simply turn so far and stiffen up without the clunk sound. Now if the valve has dropped and been sucked inside and hitting the piston, yes. The valve cannot hit anything if the keeper and spring is still in place. Either way it's simple enough to remove the covers to check.
The Following 4 Users Say Thank You to FWurth For This Post:
Old 08-13-2019, 10:24:57 AM
Wayne Riedlinger Wayne Riedlinger is offline
Those tractors are quite easy to open up to have a look inside.
The Following User Says Thank You to Wayne Riedlinger For This Post:
Old 08-13-2019, 07:48:03 PM
Jack Innes's Avatar
The AR came home today & I have opened it up to see where the trouble is. It turns better than 3/4 turn then seems to come to a spongey stop. It feels like you might pull it through but might break something. Both pistons are moving.
The valves are fine, the rods & mains are fine, the governor is free as is the fan shaft & magneto drive.
The only thing I can find is that the bolts holding the cam gear to the camshaft are finger tight & movable in their locks. Could this let the gear bind on something? Or could a camshaft roller bearing be piling up? If you turn the flywheel backwards there is a tinny clunking sound as something binds then lets go.
The last picture shows 2 threaded holes that I am guessing have a breather tube joining them. Is this just a tube or is there some sort of pcv valve in the line - I need to find that part.
Any ideas?
The ID plate reads "John Deere model A, Ser. No. 265081"
It seems like a solid machine owned by someone with a grease gun & stored inside all of its life. The rear tires are new & fresh, one wheel has some repairs & would be better replaced.
ID:	341387   Click image for larger version
ID:	341388   Click image for larger version
ID:	341389   Click image for larger version
ID:	341390   Click image for larger version
The Following 4 Users Say Thank You to Jack Innes For This Post:
Old 08-13-2019, 09:08:51 PM
FWurth's Avatar
One Millionth Post
Mouse nest or dirt dobbers in one of the cylinders? I assume you have checked to see if the valves aren't stuck. There is a breather pipe connected to the intake that is missing, no pcv in it.
The Following 3 Users Say Thank You to FWurth For This Post:
Old 08-13-2019, 10:22:13 PM
Have you checked the valve springs? they might need to be ajusted wich could mean they are either too tight or too loose.My friend has a BR that was making a snapping sound when it ran he thinks that nose is/was caused by the valve springs being too tight.Just something to check into.That serial number indicates the tractor is a 1946
Old 08-14-2019, 12:11:09 AM
It might have a bent crankshaft?
Old 08-14-2019, 04:08:39 PM
mmcdonald mmcdonald is offline
I'm not 100% clear because of the way it was written but if you can turn the crank backwards without issue but forwards it binds up my guess would be a bearing on the governor or the other thing might be a loose gear walking/binding. If it will roll backwards but not forwards I don't think it would be anything combustion chamber related such as valves, mouse nest etc. If it was mine the first thing I'd do is probably loosen the governor housing up and pick it up high enough to clear the gears and try it. If that doesn't "fix" it you'll at least eliminate a section where a problem could be. Good luck.
info@mcdonaldcarb.com
The Following 2 Users Say Thank You to mmcdonald For This Post:
Old 08-14-2019, 04:31:43 PM
Russ Hamm's Avatar
Mouse nest in one cylinder.
That will be 50 dollars.
The Following 3 Users Say Thank You to Russ Hamm For This Post:
Old 08-14-2019, 04:51:03 PM
ronm ronm is offline
Drop the oil pump. I saw an A once that sat for a few years without oil, & the pump was rusted up. It was forced to the point it split the square-tube coupler that drives the oil pump off the camshaft. Thought it had broken a tooth off the cam gear, but it didn't.
The spongy feel could be the tension coming against the coupler, if you force it & it frees up with a BANG, you just split the coupler open.
Another A I worked on had a stuck valve & it was forced enough to break a rocker arm...that will not be a solid stop either, it will feel springy until the rocker arm breaks.
But, Russ probably has it right... mouse nest...
Smokstak member #442
The Following 3 Users Say Thank You to ronm For This Post:
Old 08-14-2019, 07:45:16 PM
Jack Innes's Avatar
Thank you everyone for all of the valid suggestions. I have looked into every one of those without discovering anything. Tonight I had some time to go at it again & have discovered that the cam gear is wobbling about 3/4". It gets tight when the wobble is the worst & the gear clearance tightens up. There is no tightness in the governor gear train. I think either the camshaft is bent or the gear - both hard to imagine. It could be that the gear has shifted on the cam - the bolts are loose. Tomorrow I will remove the governor assembly & can get at the camshaft through that opening.
Does anyone know if there is someone in the Toronto area who deals in used JD parts?
Thank you all,
Jack
Old 08-15-2019, 12:51:10 AM
Jon Nessel's Avatar
Jon Nessel Jon Nessel is offline
'45 by the list I checked. It appears to have had the rad swapped out on it for an earlier one at some point, but looks like a good tractor none the less.
The Following 2 Users Say Thank You to Jon Nessel For This Post:
Old 08-15-2019, 09:22:18 AM
Not Toronto but decent prices...https://vintagetractors.com/jdauseng.html
Old 08-15-2019, 01:01:00 PM
Jack Innes's Avatar
Ronm wins the prize!!! After opening everything up & opening the oil pump for the second time it is definitely the oil pump stuck solid. I will now pull it apart & see if it is pitted too badly to use.
You need to pull the top cover off to remove the pump lines & the governor needed to come off to fix the loose bolts on the timing gear so the work is not wasted, just a long way around to find the problem. It is a good time to go through the governor as well.
I did discover that I need one rocker arm adjustment screw - it can be seen in the picture.
Jon, You are correct on the 45 ser. no. it is in that range on 2 lists I found. On the rad, it might be an earlier one but I found that JD went to a pressurized rad in 43 then in early 45 they returned to the old style using the pre 43 parts. Maybe a pressurized thermo-syphon system does not work well??
Again thank you everyone for the input.
ID:	341509   Click image for larger version
ID:	341510   Click image for larger version
ID:	341511   Click image for larger version
The Following 7 Users Say Thank You to Jack Innes For This Post:
Old 08-18-2019, 09:28:01 AM
Jack,
It may be too late, but if you can at all, just drop the gears out the bottom of the pump. Working with the oil pipes on the pump & filter is pure Hell with the crank & block in the tractor...something I have done twice in my life, & will never do again...if you can get the gears free & the housing is any good at all, just go with that. It only runs 15 psi oil pressure anyway, the pump doesn't have to be pristine...
The Following 2 Users Say Thank You to ronm For This Post:
Old 08-18-2019, 10:30:34 AM
Jack Innes's Avatar
Ron, You are 100% correct. It is a terrible job with the crankshaft in place. But the pump is now all cleaned up & back in the case. The gears would not come out as they were stuck in place by solidified sludge & a bit of rust. The oil had been drained several years ago & that likely caused this. I also found sludge lumps inside the screen & one oil line had loose solder fittings so in the end there was an advantage in having it all apart.
I am currently replacing the governor bearings, then it can go back together.
The Following 5 Users Say Thank You to Jack Innes For This Post:
Old 08-19-2019, 08:21:55 PM
Jack Innes's Avatar
Would someone be able to post a picture of the breather pipe that goes from the governor housing to the air intake? It must have some sort of swivel joint to allow it to screw into the 2 female threads. I need to find this but do not know what I am looking for.
Thank you,
Jack
Old 08-19-2019, 10:30:43 PM
Nathan K. Nathan K. is offline
Hi Jack,
Haven't looked at my AR for a while but think it's just an L shaped tube with 2 male packing nuts to seal the ends-with both nuts loose it can be wiggled in or out. You could look at the JD parts page might show it.
Nathan.
The Following 2 Users Say Thank You to Nathan K. For This Post:
Trouble starting John Deere 1 1/2 hp engine slade12178 Hit & Miss Gas Engine Discussion 16 07-23-2017 03:22:11 PM
John Deere G carburetor trouble Dave Wiesman Antique Farm Tractors 7 08-16-2016 08:36:13 AM
John Deere D Magneto Trouble 1929 John Deere D Magnetos, Ignition Coils and Spark Plugs 6 12-01-2012 08:11:59 PM
John Deere 1 1/2 E Governor Trouble Butch50 Hit & Miss Gas Engine Discussion 7 11-17-2011 10:43:35 PM
Mid 70's John Deere 110 trouble! Johnchukoloski Garden Tractors and Mowers 7 02-07-2010 11:36:01 AM
