Wisconsin Engines
AHH RIP... Parts available
this thread has 4 replies and has been viewed 372 times
Old 08-27-2019, 07:53:55 PM
anwalker anwalker is offline
Default AHH RIP... Parts available
The oil pan apparently came loose last night and destroyed the engine. Crank is shot, rod is shot, piston and cylinder scored. I don't know how this happened, engine was running awesome then I heard her come apart interally. It still started and ran which was amazing but she's toast. Let me know if anyone needs parts that are left....
Old 08-27-2019, 09:47:11 PM
radiodoc radiodoc is offline
Default Re: AHH RIP... Parts available
Is the air shroud in good shape? I may be interested. Allie
Old 08-27-2019, 11:00:30 PM
I sandblasted it and welded most of the holes. It's not show quality but is functional.
Old 08-28-2019, 09:36:08 AM
K-Tron K-Tron is offline
I would like to see what the crankpin and connecting rod look like after this failure. It is unlikely that the oil pump failure caused the piston to score the cylinder; you would have had to work it hard and hot to cause that damage. You can have the crankshaft ground and a new rod installed if you so desire to put it back into service. I have never seen or heard of an oil trough walking off of the oil pan before. It must not have been bolted down. From what it sounds like, your Heckendorn stump grinder is just one of a few of its kind left. I would try to fix it before scrapping or parting it out.
Chris
The Following User Says Thank You to K-Tron For This Post:
Old 08-28-2019, 09:15:22 PM
Zira Zira is offline
All of that is fixable, if you want to put that much time/effort/$ into it. Unless it uses an odd crankshaft, probably wouldn't take much $.
12-20 Twin City Cylinder Head Parts interchangeable to new available parts. jesters13 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 05-31-2017 11:37:59 PM
Clinton Master Parts Price list (1964) & parts cross-reference TractorDom Small Air Cooled Gasoline Engines 0 11-26-2015 11:02:54 PM
Digitize 3D Parts, Broken parts, etc. Great video shown at Jay Leno's Garage Dusty Hit & Miss Gas Engine Discussion 0 04-10-2013 11:19:56 AM
Looking for Goold shapley and muir 3 1/2HP parts and to contact others needing parts Nathan K. Hit & Miss Gas Engine Discussion 8 03-16-2013 11:52:47 PM
Online Onan Parts Sales-or at least a parts number B.Ikard Onan Generators 3 06-21-2007 07:07:12 AM
