Wisconsin Engines
Wisconsin AENLD Piston Rings?
this thread has 2 replies and has been viewed 188 times
Old 09-05-2019, 09:46:18 PM
tkanderson's Avatar
tkanderson tkanderson is offline
Default Wisconsin AENLD Piston Rings?
Been looking for a set of rings for my Wis. AENLD. The parts cat. shows the set as "DR6E". Having problems locating a set of standard size. Is there a cross ref #..? or are they just hard to find..?
Old 09-05-2019, 10:16:36 PM
K-Tron K-Tron is offline
Default Re: AENLD Pistone Rings....???
Tim Stine at Rock Creek Consulting 1-814-766-3675 will have the DR-6E rings that you are looking for. The Tri-Crome alternative is the DR-37. Unless your bore is really bad, i'd stick with the cast iron DR6 ring set.
Chris
Old 09-06-2019, 12:41:45 AM
tkanderson's Avatar
Default Re: Wisconsin AENLD Piston Rings?
Very nice and thanks a ton! This is my first restore on a Wisconsin, been busy with older hit and miss and Lauson motors. The motor exterior was a nightmare but the internals look great. I usually replace the valves, piston, rings and bearing just out of habit and I'm there. The cylinder wall looks great and measure within spec. I'll post it here as the "new guy" after I'm finished. Thanks for the lead!!
Wisconsin VM4 Piston and Rings K-Tron Wisconsin Engines 0 12-29-2018 07:23:47 PM
Wisconsin ADH Piston Rings robertverwer Hit & Miss Gas Engine Discussion 2 10-13-2017 09:46:56 PM
AENLD - piston ring set - opinions? kww1184 Wisconsin Engines 4 07-01-2014 10:21:53 PM
Wisconsin AENLD Bill Sherlock Wisconsin Engines 4 05-09-2009 02:05:52 AM
Piston Ring Material for Custom Machined Piston Rings. Uncle Old Iron Hit & Miss Gas Engine Discussion 3 06-24-2007 01:50:53 AM
