Wisconsin Engines
Semi trailer reefer motor
this thread has 5 replies and has been viewed 418 times
Old 09-22-2019, 01:21:17 PM
q930 q930 is offline
Default Semi trailer reefer motor
I have an AK that was reportedly from a 1940s or 50s reefer trailer. Are there any old time truckers that remember these units (photo attached) hanging on the front. Were they exposed to the weather like that?
Name:	reefer motor.JPG
Old 09-22-2019, 03:19:25 PM
Default Re: Semi trailer reefer motor
It looks like that wasn't unusual.
Images from https://www.singingwheels.com/reefers.html
Old 09-22-2019, 05:37:15 PM
K-Tron K-Tron is offline
Thermoking used Wisconsin AENL engines with large centrifugal clutches on them to run refrigerating compressors at least through the 1970s. A friend recalls rebuilding one of these engines at least five times since it wore out two cast iron sleeves. He said it must have had many thousands of hours of run time on it. I do not recall ever hearing about an AK on a reefer trailer. The older units like Wayne posted were usually a small cast iron Briggs & Stratton with a fan mounted on the crankshaft. I have seen them as model B's, Z's and 23's. I have never seen one setup like that with a Wisconsin until now. I would love to see some pictures of the engine you have and how it is setup.
Chris
Old 09-22-2019, 05:59:13 PM
PLCtech PLCtech is offline
When I worked on Thermo Kings, they were Mercedes Benz (older ones) or Isuzu (newer ones).
Old 09-22-2019, 08:55:12 PM
Kothe Kothe is offline
I have a Thermoking ( Wisconsin AENLD ) with the deep pan and centrifugal clutch with electric start , runs great
Old 09-23-2019, 06:51:36 PM
Zira Zira is offline
I have an AK from a reefer truck, I think but am not sure it was a ThermoKing brand.
Backfeeding Grid With 5 Semi Trailer Gensets Birken Vogt Generators & Electric Motors General Discussion 10 05-26-2017 12:48:14 AM
Railroad reefer car gen set? KeithW Multi-Cylinder Stationary Gasoline Engines and Power Units 11 04-21-2015 10:32:22 PM
Who Invented the Semi-Trailer? Oberon67 Trucks, Trailers and Hauling for Shows 20 03-26-2013 12:45:20 AM
Loading tractor on a tilt bed semi trailer thejunkman Trucks, Trailers and Hauling for Shows 0 03-20-2011 04:40:24 PM
