generators
this thread has 6 replies and has been viewed 2528 times
Old 10-16-2005, 07:11:35 PM
Gaston Gaston is offline
Unhappy generators
have a 7.5 marine onan. has 4 wire output. has little power on each leg have it hooked up 240 volt. before i buy a new regulater board can i excite the generater with 12 volts to see if its any good?
Old 10-16-2005, 09:39:37 PM
Gunny Gunny is offline
Default Re: generators
Model and spec?
Old 10-17-2005, 07:42:28 AM
mdje. can't read spec is diesel 2 cylinder
Old 10-17-2005, 03:25:05 PM
BTPost's Avatar
BTPost BTPost is offline
MDJE is a common 2cyl 7.5Kw Water Cooled diesel Genset. This model usually
has an Onan YD Genend attached. The YD Manual has all the wiring diagrams for the "J" series engines in the back. Manual number is 900-0184 and is
available from any Cummins/Onan Dealer. Be nice to know what the voltage
Genend Spec is? (3C, 18, 9X, ect)
Bruce in alaska
Old 10-18-2005, 01:25:29 PM
more info . model mdje spec 3cP /2268 ad
Old 10-18-2005, 03:29:05 PM
BTPost's Avatar
The -3C means you have the YD Genend, with two 120Vac Sator windings,
that can be connected, in series for 120/240Vac, or parallel for 120 Vac,
Single Phase. By dropping the neutral from the center of the series connection, you can have 240Vac single Phase as well. Nice for Standby
for a house or Prime Power for a cabin. A neighbor has both an MDJE, and a DJE in his cabin's powerhouse. He went and got a import car radiator with an electric fan, and put that in the Secondary Cooling Loop and removed the Wet Exhaust completely. He uses the cooling loops heat for CoGen Hotwater,
and cabin heat, instead of burning up a lot of firewood in the winter. Works out very nice, as he only needs to run it a couple of hours a day to keep the inverter batteries charged.
Bruce in alaska
Old 10-19-2005, 11:06:45 AM
excited generater f-1 and f2 wires with 12 volts . generater powers up fine. need to know what is wire 1 and 2 which also goes to generater and b 2 .this wire goes to a restister and then to the battery .I don't want to install a new cutcuit board till im sure this other stuff is working too. thanks for any help!
GMG generators Billy J Shafer Military MEP and Aircraft Gen-Sets 8 05-14-2015 12:01:54 PM
Old car Generators as Starter/generators dhiesel Small Air Cooled Gasoline Engines 7 07-18-2012 01:41:03 AM
Syncing two generators or sinking generators James Storm Generators & Electric Motors General Discussion 7 03-03-2010 04:45:15 PM
New Old generators Johnny Williams Generators & Electric Motors General Discussion 4 11-19-2005 05:55:50 PM
Why generators? Mac Leod Antique Engine Archives 3 02-20-2004 01:48:45 PM
