Steam Engines
chrome removal
this thread has 2 replies and has been viewed 3264 times
Old 04-10-2007, 04:09:37 PM
Dan Dyman
Default chrome removal
I have an oiler which is chrome plated,it looks to be quite thick plating all over, the base metal is bronze? possibly brass but as its in contact with steam I doubt it is brass, I want to remove the chrome without doing any damage to the base metal, anyone got any clue as to how to do his?
Old 04-10-2007, 06:31:49 PM
Exclamation Re: chrome removal
Oiler body probably IS Brass or more likely Bronze. Are you sure it is Chrome, and not Nickle? On older high priced (better)oilers, Nickle was the plating of choice. I suppose acid etching - electrolytic stripping, is the way to go, but it is not really practical. Any method will probably damage the base metal. you are probably better off finding a diferent oiler, rather than trying to strip the current one. If the reason for removing the old finish is because it is in poor shape, why not take it to a plating shop, and have it re-finished? Might be cheaper in the long run
Old 04-10-2007, 06:54:43 PM
Default Re: chrome removal
Electrolisis will work just fine and doesnt take very long.You will have to polish the brass as it will become dull
Removing chrome vern0n Antique Autos and Trucks 2 11-09-2013 07:49:37 AM
Chrome Plating Removal Ray Cardoza Hit & Miss Gas Engine Discussion 5 06-07-2011 08:18:36 PM
Removing chrome JIM ALL Machine Shop and Tool Talk 8 11-20-2007 11:33:46 AM
