My first engine (3HP Jaeger)
this thread has 30 replies and has been viewed 3332 times
Old 01-22-2009, 01:48:41 AM
Elwood Elwood is offline
Default My first engine (3HP Jaeger)
hi all, i just got my first engine, its a 3 hp jaeger,
i have a few questions id appreciate help with..
the engine runs good, i saw videos of it b4 i bought it,
its been setting for over 30 years, its got the usual grease or dirt soaked oil packet all over it,
id like to clean it up, change the oil, clean the plug, and oil every think up b4 i start it.
and naturally i dont know squat about this ol thing, id really like a good service manual.
i was thinking about soaken it down with pb blaster penetrating oil and using rags to clean it as good as possibly, it still had 90 % of he paint still on it.
any good tips on cleaning these ol things ? id like to remove the water tank too, and clean every thing.
thanks ..
elwood
ID:	47078   Click image for larger version
ID:	47079   Click image for larger version
Old 01-22-2009, 08:31:15 AM
Walt Beeman's Avatar
Walt Beeman Walt Beeman is offline
Default Re: my first engine
Elwood,
Congatulations, hope you have lots of room, the Iron Fever will soon take hold. Try to find a local club and you will most likely find someone eager to help someone new. The sponsors here on the Stak sell manuals, there is also a registry for Hercules built engines, search this site and you should find all of the neccessary information. Can you post pictures and serial and model numbers, the help you get can be more specific that way. My first one was also a Jaeger, mine required lots of work and lots of parts, I learned a lot bringing it back from the grave. I had an engine buddy there to help when I first got it running, he showed me all of the things to watch out for, how to adjust things, and most importantly, how to shut it down if things got out of hand. I strongly suggest doing the same, nothing beats experience, besides, it's a lot more fun to have a friend there. Jaegers are real nice runners, you should enjoy having it.
Keep Enjoying Old Iron,
Walt Beeman
Old 01-22-2009, 08:40:58 AM
wegotallama's Avatar
wegotallama wegotallama is offline
Hi Elwood
I got my first engine this last fall. And it too is a Jaeger! Like Walt said, check the sponsors here. You can get everything you need and help keep the site going.
Post photos when you can.
Old 01-22-2009, 09:07:23 AM
hey guys, thanks for the reply,
i tried posting some pictures to the test forum but had no luck doing so..
here is a you tube link to the videos the guy sent my b4 i bought it.
http://www.youtube.com/watch?v=UUQYBUssa9c&NR=1
i have a feeling this is goanna be a very fun new hobby or maybe obsession, hah.
i went out to my shop last night at 12.30 and 3 something, wow, i hope sleeping gets easier, smile ...
thanks for the welcome..
elwood
The Following User Says Thank You to Elwood For This Post:
Old 01-22-2009, 10:29:05 AM
Rag
Wow. He must have had the fuel mixer loaded to gas to get it started with the choke plate wide open !!! I doubt if it could draw fuel from the tank with no choking. With the plate 70% closed it would have run without repeated squirts of fuel.
Looks like you bought a good one. Have fun.
Old 01-22-2009, 10:58:37 AM
Junkologist's Avatar
Default Re: My first engine (3HP Jaeger)
I saw that engine on eBay. You have a nice engine for your first. I know you want to tear into it and work on it, but if it ain't broke, don't fix it. Just give it a good cleaning on the exterior. I wouldn't remove the hopper (water tank) unless I absolutely had to. You can clean it out just fine by using a shop vac with crevice attachments or sometimes I will duct tape a piece of garden hose to the vac hose to get in the tight spots. Get a good stiff piece of wire and use that to loosen up junk down in the bottom below the cylinder and vac it out or flush it out through the drain hole.
Mike
SmokStak member #146
Old 01-22-2009, 10:59:34 AM
Russell M's Avatar
Russell M Russell M is offline
Great looking Jaeger. Jaegers were made by Hercules in Evansville, IN. I have one like it but is was a rust bucket and had top be repainted. You can get most any part you need from vendors on this site. I did notice that you have a fuel filler hole on both sides of the base.
Old 01-22-2009, 11:56:39 AM
Elden DuRand's Avatar
Elwood:
If you are in an area that you can get away with hosing it off, get some Gunk at your auto parts store and use it per instructions. It is not harmful to paint or decals (as far as my experience goes) and the only thing you will have to do afterward is to lightly oil the exposed metal surfacts to retard rusting.
To clean out the cooling hopper, just remove the drain cock to give the biggest opening and use a garden hose to flush out what rust and crud you can get to. What's left won't hurt a thing.
Welcome to the hobby (obsession)!
Take care - Elden
Old 01-22-2009, 12:24:55 PM
Larry Rusch Larry Rusch is offline
Nice piece of iron!....not to change the subject, but, what's the story on that flattie in the background???
Old 01-22-2009, 12:43:01 PM
fm00 fm00 is offline
Congrats....using a $2 can of WD-40 spaying it all over, wiping off, works great for cleaning up ANY thing, old, painted. It puts a nice coat to protect it too. WD-40 makes a spray bottle, I like using it this way with buying it in the big cans. If you can't find that, the spray cans will work, they just don't mist as nice as that bottle you fill.
Old 01-22-2009, 12:53:34 PM
Peter Ruffle's Avatar
Peter Ruffle Peter Ruffle is offline
Great looking engine!! A good cleaning and you will have a very nice looking engine. And yes inquiring minds want to know all about what looks like a well dressed flattie in the background??
Old 01-22-2009, 01:16:01 PM
hound51 hound51 is offline
Hello When you get it running close the chock plate up some on it. You may also need to turn the needle value on it also. close it off and start to turn it about a quarter of a turn are more on it to where it start to run good on it .Hope this will help you some. Good luck on it
Old 01-22-2009, 02:29:39 PM
Sky
I had to look at that myself. Looks pretty neet I bet that was somewhat complicated to make that a fuel injected kit. Thats somethin how you can here the plugs fire in the video. Probably not resistor plugs then.
Old 01-22-2009, 03:51:22 PM
Ray Cardoza's Avatar
At least you know its a running engine. yuo've got half the battle done. now just to get it running right. good luck and have fun
Old 01-22-2009, 10:45:47 PM
hey thanks to all you guys that replied to my post, im haven a great time already with my new little engine,
i guess im headed out to the shop now to work on cleaning it up.
i guess im goanna use wd40, i have that and pb, but ive always loved using wd40, smile, maybe the way it smells hu..
im ordering service manuals for my jaeger and my stover from this sites sponsors, and i plan on being a regular here,
and to those who ask, the flatheads in the back ground are my first love for years now, i have 5 running ford v8 flatheads and 2 none running ones.
something about old engines just draw me in, and i sware, the oil blow by on this jaeger smells just like my flatheads, hah
cheers
Old 01-22-2009, 10:50:53 PM
Default picture stuff, sry ot ..
hey i posted some pictures and a link to my jaeger on you tube, but i didnt think it worked, did someone help me out ?
if i got it wright, cool, if someone helped me, i appreciate it very much and would love to learn how you did this, hah.
cheers,,,
elwood
Old 01-22-2009, 11:13:20 PM
Default Re: picture stuff, sry ot ..
probably good ol craig doin his "magic" just helping you out. i dont know how he does it though.
Old 01-25-2009, 03:52:20 AM
Default some clean up pics
hey all, i did a few things to my jaeger,
first i wanted to clean the fuel system, so i removed the gas tank, it is broken where the filler goes in, removed the exhaust manifold to get the carb off,
i soaked the carb and various small parts in carburetor cleaner for a couple days, didn't soak the gas filler cause i didn't wanna lose the paint, so im hand cleaning it.
i soaked the engine for 3 or 4 days with wd-40 then scrubbed it with solvent i use at work to clean transmissions, then washed it with hot soapy water. rubbed it all down and used compressed air to help get it dry.
then i rubbed it down with ATF, then rubbed it all in or off.
i scrapped the water tank, blew a bunch of air in it and flushed it, left it soaked with pb blaster, goanna re-flush it in the morning.
i cleaned the mag contacts with break cleaner, and put electric contact silicone on the contact points.
humm what else,
well i ordered a service manual and a spark plug and a gas tank and new fuel line with a valve in it from hit n miss.
well so here are some pictures, hope not to many,
oh, i cleaned all the oiling holes with a pic and air, 5 i think or maybe 6, and put oil im em, i cleaned most of the old hard yellow grease outta the greasers and put industrial black molly in them and screwed them and refilled and screwed them till i have black molly coming from all arias, then of course, cleaned up the mess.
ran a bunch of clean 30w non detergent oil through the piston oilier hole,
i pulled the spark plug and rolled it over and over till i got all the new grease and oil flowing outta every where.
ok, hope this ant to much..
cheers.
elwood
http://i246.photobucket.com/albums/g...Picture039.jpg
http://i246.photobucket.com/albums/g...Picture043.jpg
http://i246.photobucket.com/albums/g...Picture045.jpg
http://i246.photobucket.com/albums/g...Picture052.jpg
http://i246.photobucket.com/albums/g...Picture057.jpg
http://i246.photobucket.com/albums/g...Picture067.jpg
http://i246.photobucket.com/albums/g...Picture068.jpg
http://i246.photobucket.com/albums/g...Picture076.jpg
http://i246.photobucket.com/albums/g...Picture079.jpg
http://i246.photobucket.com/albums/g...Picture081.jpg
http://i246.photobucket.com/albums/g...Picture085.jpg
Old 01-25-2009, 03:58:06 AM
IronCity2006's Avatar
IronCity2006 IronCity2006 is offline
Location: Hoopeston, Illinois (90 miles south of Chicago)
Default Re: some clean up pics
I cant see your pics but you sound like a proud daddy!
Old 01-25-2009, 04:02:29 AM
yea i am, my first old engine,
i gotta bunch of flathead v8s but it ant the same.
Jaeger engine with 2 tags? JKKD Hit & Miss Gas Engine Discussion 3 09-24-2007 09:06:45 AM
jaeger engine Steve Kreiner Hit & Miss Gas Engine Discussion 2 05-03-2006 09:48:42 PM
Jaeger Engine Monroe Johnson Hit & Miss Gas Engine Discussion 1 09-20-2005 11:16:23 PM
Jaeger engine Selina M. Knight Antique Engine Archives 1 09-12-2003 05:48:43 AM
Jaeger Engine Michael Nack Antique Engine Archives 3 09-15-1999 10:31:56 PM
