1906 Bing spirit engine vapouriser how?
this thread has 8 replies and has been viewed 4640 times
Old 11-18-2009, 09:30:53 AM
benz1890 benz1890 is offline
Default 1906 Bing spirit engine vapouriser how?
I've had this lovely little Bing four stroke hot tube spirit engine in my possession for quite some time now and thought it's time to make some steps into it's restoration.
I need to know how the spirit vapouriser works? Is it similar to the Daimler/Benz type of vapourisers for Petrol(Gasoline), this is when the air intake draws air through the vapouriser bubbling it up through the petrol so forming a gas?
Is spirit basically Methylated Spirit?
I hope this interests someone into giving me an answer!!
Mike.
The Following 2 Users Say Thank You to benz1890 For This Post:
Old 11-18-2009, 10:47:24 AM
Elden DuRand's Avatar
Default Re: 1906 Bing spirit engine vapouriser how?
Mike:
I know next to nothing about what you ask but that doesn't deter me from commenting.
I guess "methylated spirit" is methyl alcohol. It would easily vaporize and probably have enough energy to run the engine.
In lieu of that, you could try something like naphtha.
Neat little engine! Keep us informed about your restoration progress.
Take care - Elden
Old 11-22-2009, 12:18:10 PM
Isn't naphtha closer to Kero?
Mike
Old 11-24-2009, 08:33:40 PM
Dusty's Avatar
Dusty Dusty is offline
The term “Naphtha” is usually restricted to a class of colorless, volatile, flammable liquid hydrocarbon mixtures. Obtained as one of the more volatile fractions in the fractional distillation of petroleum (when it is known as petroleum naphtha), in the fractional distillation of coal tar (coal-tar naphtha), and in a similar distillation of wood (wood naphtha). Coal-tar (aromatic) naphthas have greater solvent power than petroleum (aliphatic) naphthas. Originally the term Naphtha designated a colorless flammable liquid obtained from the ground in Persia. Later it came to be applied to a number of other natural liquid substances having similar properties. Technically, gasoline and paraffin (kerosene) are considered naphthas.
Naphtha is not to be confused with Naphthalene (also known as Naphthalin, Naphthaline, Tar Camphor, White Tar, Albocarbon, or Naphthene), which is a crystalline white solid hydrocarbon, and having a typical mothball odor. Naphthalene is also volatile, forming a flammable vapor. It is manufactured from coal tar (the liquid by-product of the distillation of coal to make coke. The gaseous by-product by this same process is commonly known as town gas).
Naphtha is a fuel fraction between light motor spirit and paraffin. Extensive research was conducted and the following physical data descriptions documented:
Gasoline Naptha Paraffin
Specific Gravity .68-.76 .74-.75 .80-.81
Flash Point -43 deg F. 52 deg F. 170 deg F.
The Following User Says Thank You to Dusty For This Post:
Old 11-25-2009, 05:23:15 AM
Am I right in saying that it doesn't vapourise easily at room temp or lower?
I guess spirit is Gasoline or lighter???
Mike
Old 01-26-2011, 06:09:26 PM
steamdoctor steamdoctor is offline
hello, i am Frank from germany and i am new here. I have found here your Bing spirit engine, i am very, very interestet to buy the engine for my collection. If you are interested please write to me. frank.kautznerQt-online.de
It doesn't matter if there are parts missing.
Old 01-26-2011, 08:07:17 PM
I think that you are correct about the vapouriser also called an evapouration carburator. check this Utube http://www.youtube.com/watch?v=bfzrTr_vYZw I think that I would use naptha rather than gasoline. When the gasoline vapourises it draws off the lighter distillates first which leaves you with a low volatable mixture. Ron
---------- Post added at 07:07 PM ---------- Previous post was at 06:57 PM ----------
There are some similarities to my Schoenner engine with 6" flywheels. The Schoenner is a non compression engine that uses lighting gas. Ron
Old 01-26-2011, 08:13:54 PM
Here is the picture of the Schoenner.
The Following User Says Thank You to Ronald E. McClellan For This Post:
Old 01-26-2011, 09:22:58 PM
Bill O Bill O is offline
Two controls are needed on the vaporizer. The air that has bubbled through the fuel is too rich and needs a separate controlled air bleed as well as another control on how much of the blend goes into the piston chamber. A nice story on the vaporizer for the full size engine was just on the Stack.
Check the Stack for the 8 connected threads of "1883 Daimler Experimental Engine Project" and the excellent machining by Wayne Grenning.
Bill O.
---------- Post added at 08:22 PM ---------- Previous post was at 08:06 PM ----------
It appears to me that your vaporizer is missing and it will be a project to replace it. Perhaps the float portion of the vaporizer that is used on the Daimler engines may not be needed, just a bubbler and a gasoline system can be made, but be careful and use a safe way to avoid a backfire to your vaporizer and note the hot tube flame is beside the fuel system.
"Gebruder Bing Nurenburg" engine find petrol smoker Vintage Toy Steam Engines and Motors 5 01-11-2009 02:44:16 AM
Pictures of Old Farm Days, Spirit of the Swannee park redfish443 Hit & Miss Gas Engine Discussion 1 11-30-2008 04:22:56 PM
1906 cadillac engine Ralph Antique Engine Archives 2 07-20-2004 11:37:06 PM
1906 Oldsmobile Stationary Engine Dean Antique Engine Archives 0 08-21-2003 06:57:52 PM
