Mid 70's John Deere 110 trouble!
this thread has 7 replies and has been viewed 4523 times
Old 02-06-2010, 01:40:38 AM
Johnchukoloski Johnchukoloski is offline
Default Mid 70's John Deere 110 trouble!
I've got this JD 110 that i just got running and it was running rough and wanted to die as soon as I turned the choke off. Carb adjustments didn't do any good. While the tractor was running and I was frustrated I decided to let the tractor run while I removed the battery as to recharge it over night. The second I unhooked the possitive terminal the engine smoothed right out so I quickly hooked the possitive back up, just to see and it instantly run real rough again then I unhooked it and is instantly ran amazing!
What in the world could the battery have to do with my tractor acting like this?
Thanks all,
John.
Old 02-06-2010, 02:46:31 AM
John Newman Jr.'s Avatar
John Newman Jr. John Newman Jr. is offline
Default Re: Mid 70's John Deere 110 trouble!
What is the engine in it?
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 02-06-2010, 03:06:02 AM
Kris Golden Kris Golden is offline
I think your coil has been hooked up backwards ???
Old 02-06-2010, 05:50:34 AM
Johnny T Johnny T is offline
I'd say coil or condenser problem. Make sure + is closest to battery/ electrical components, and - is what leads to the points cover. And if that don't fix it, if i remember right JD's use a rectifier as opposed to a regulator, that could be causing a prblm, but I'd check coil and especially condenser. Also make sure the coil and condenser are GROUNDED!
John
Old 02-06-2010, 10:20:40 AM
Is John Deere different than other tractors? Every tractor I've ever known has had the points wire and condenser wire hooked up to the (-) on the coil.
Old 02-06-2010, 03:54:34 PM
Mark Birdeau's Avatar
Mark Birdeau Mark Birdeau is offline
A JD 110 should be a negative ground, so yes,as Johnny T said,the - on the coil should go to the points. If your 110 is like one of the one's I have both battery cables are hooked up real close to the same spot. If you don't look real close it is easy to get them mixed up and hook them up backwards. You should be able to unhook the rectifier to see how it runs then, but the battery would still need to be hooked up. Mark:
Old 02-06-2010, 11:28:48 PM
Exclamation Re: Mid 70's John Deere 110 trouble!
Points are connected to - (Neg.) side of the coil. Check the state of charge and condition of the battery. If the battery has damaged plates or voltage is extremely low then voltage supply for ignition will be too low. Check all grounds, especially engine and battery to deck as poor grounds will cause feedback thru the ignition system. Do not run engine on the alternator for long, as tie loading factors will damage the regulation system. make sure the battery is hooked up properly, + to + and - to -. reversed polarity, even for a second will fry the diodes and regulator. If you jump start the battery, again check for proper polarity. Remember, if it is below 32 degrees F and the battery is in a discharged state, the low specific gravity will allow the electrolyte to freeze. This will destroy and short the plates internally, and the battery will not charge properly, if the electrolyte is frozen. Trying to charge a frozen cell may result in an explosion!
Old 02-07-2010, 11:36:01 AM
Smile Re: Mid 70's John Deere 110 trouble!
Thank you all for your input! Yesterday I cleaned all connections and when I say all I mean ALL including all points of ground contacts! When I was done it fired right up and ran beautiful! Thank you all so much!
John.
Early 70's JC Penney rider w/dune buggy body jjackson Garden Tractors and Mowers 17 05-14-2018 12:09:18 PM
John Deere E help CLips221 Hit & Miss Gas Engine Discussion 2 04-16-2008 12:35:21 PM
John Deere type E fuel system trouble Tom Antique Engine Archives 6 08-02-2004 12:24:14 PM
1 1/2 HP John Deere Dave Valentine Antique Engine Archives 19 03-14-2003 11:51:01 PM
John Smyth has rod trouble Bill Wehrman Antique Engine Archives 6 02-02-2002 12:30:46 AM
