P.K. Lindsay Portable Air Compressor
this thread has 2 replies and has been viewed 6422 times
Old 01-05-2011, 10:05:54 PM
RBWK RBWK is offline
Default P.K. Lindsay Portable Air Compressor
My father in law just pulled this thing out of a storage unit today and I'm not really sure what exactly it is. All I know is it's rather old and name plate says P. K. Lindsay Portable Air Compressor. Later this week where gonna get it running. Does anyone have information on user manual. I put up a few photos. I searched on the internet for more information on how to get it running or parts etc... nothing... anyone?
ID:	97258   Click image for larger version
ID:	97259   Click image for larger version
ID:	97260   Click image for larger version
The Following 2 Users Say Thank You to RBWK For This Post:
Old 01-05-2011, 11:08:15 PM
Junkologist's Avatar
Default Re: P.K. Lindsay Portable Air Compressor
This video of my Lindsay should give you an idea of how it works. The only differences between yours are mine is the engine models and the way the air is piped to the tanks. Mine is a Briggs model Q and yours is a Briggs model R. Yours was probably built in the early '30s. Looks like a nice one! I'd like to find one like it someday myself.
Mike
SmokStak member #146
The Following 6 Users Say Thank You to Junkologist For This Post:
Old 01-06-2011, 09:45:16 AM
Jonathan Widelo's Avatar
Nice Find!
I and other collectors have looked for literature on these units, and as far as well noting still exists. I have written to the company who purchased the assets of the original PK Lindsey Company, with pictures of my compressors but have never heard back. The best advice I can give you about starting these units up is to un screw the safety valve so the unit holds no air until you can verify it works and the tanks are safe told pressure. There is also knob on the air compressor power head that will disable it for easy engine starting. The engine should be easy to get running, make sure you have spark and compression and both the carb and gas tank are clean. Also if it hasn't been run a while I would change the oil. I usually run SAE 20wt oil in these old Briggs, it is available from Tractor Supply Company.
~ Jonathan
The Following 2 Users Say Thank You to Jonathan Widelo For This Post:
Lindsay Air Compressor Parts - Where to get? jrk Air Compressors 4 08-14-2018 04:12:39 PM
I Joined the Lindsay Compressor Owner's Club Today Junkologist Small Air Cooled Gasoline Engines 42 03-04-2012 11:14:16 AM
My new Lindsay Compressor and questions David K Small Air Cooled Gasoline Engines 2 04-05-2010 11:01:56 PM
Merkel Engine Lindsay Air Compressor Junkologist Small Air Cooled Gasoline Engines 14 03-14-2010 04:25:53 AM
Briggs Model ZL on a Lindsay Air Compressor Jonathan Widelo Small Air Cooled Gasoline Engines 15 05-27-2009 11:15:55 PM
