Go Back   SmokStak > SmokStak® General Discussion > YouTube Old Iron Videos
YouTube Old Iron Videos A place to show your ON topic movies of antique engines and old iron.
Lindsay Air Compressor
this thread has 8 replies and has been viewed 3903 times
Old 02-13-2011, 10:53:20 PM
Tim B's Avatar
Tim B Tim B is offline
Photo Lindsay Air Compressor
Sorry about the long video, I still need to sit down and figure this editing/cutting thing out. Enjoy
Old 02-14-2011, 10:54:15 AM
Exclamation Re: Lindsay air compressor
I had the same compressor, but a little older. It had a Bosch mag with horseshoe magnets, and a different carb, otherwise identical to yours. They are neat outfits! I had to replace the big end con rod bushing on mine. The crank is open ended, like a model airplane engine, or the maytag 82 and upright engines. On my engine, the rod was one piece, with the bronze bushing pressed into the big end. A bolt and washer kept the rod on the con rod throw! On my engine, the head and cylinder were nickle plated, as was the carb.
Old 02-14-2011, 06:19:29 PM
Tim B's Avatar
Default Re: Lindsay air compressor
Yeah, Ive seen a couple different mags. I dont know if they came w/ different mags or they were junk and everyone changed them. A buddy of mine has one w/ a Splitdorf. Kind a squared off horseshoe magnets. It's hard to tell in the video but this cylinder,intake,carb, exhaust is Nickel plated. Be nice if it was cheap to have it all redone. Do you know what kind or carburetor you had on yours? Was it original? Thanks, Tim
Old 02-14-2011, 06:45:27 PM
Junkologist's Avatar
Very nice, Tim! That's the nicest running Merkel Lindsay compressor I've seen, although I've only seen two run, yours and mine! I like the crank hanger. Mine doesn't have that feature. Your compressor rocker arm is different than mine also. I've found the proper magneto for mine, a Dixie M-1. It's coming all the way from Australia!
I guarantee it will draw a crowd at any show you take it to. Mine always does.
Mike
SmokStak member #146
Old 02-14-2011, 10:33:03 PM
krawlr's Avatar
krawlr krawlr is offline
Default Re: Lindsay Air Compressor
That is the coolest little compressor ever.
Don Edwards
With a sawzall and a MIG welder, everything fits everything.
The Following User Says Thank You to krawlr For This Post:
Old 02-14-2011, 10:48:19 PM
Tim B's Avatar
Sounds great on the mag, Mike. Australia must be a nice place to visit. I got an original manual for my Matthews JR lightplant from there. I should of spent more time on the video. I was messing around w/ the engine a little more, and seems like it will idle down real low, sounds great. Well thanks everyone for the comments. Tim
Old 02-14-2011, 10:52:02 PM
darrin darrin is offline
Tim,nice job runs great wish I could find one would be great for light work around the house ,hope all is well thanks for the vid Darrin
The Following User Says Thank You to darrin For This Post:
Old 04-12-2011, 01:12:51 AM
rustyknutt rustyknutt is offline
What an amazing piece of historical engineering. This is why we hit junkyards and fencelines and behind old barns.
Old 08-16-2011, 08:25:35 PM
gt4 gt4 is offline
That is awesome, just fantastic, i cant say enough.
The Following User Says Thank You to gt4 For This Post:
Lindsay Air Compressor Parts - Where to get? jrk Air Compressors 4 08-14-2018 04:12:39 PM
Lindsay Air Compressor, Briggs W :0 Randy Hart Small Air Cooled Gasoline Engines 9 01-25-2011 11:02:19 PM
P.K. Lindsay Portable Air Compressor RBWK Hit & Miss Gas Engine Discussion 2 01-06-2011 09:45:16 AM
My new Lindsay Compressor and questions David K Small Air Cooled Gasoline Engines 2 04-05-2010 11:01:56 PM
Briggs Model ZL on a Lindsay Air Compressor Jonathan Widelo Small Air Cooled Gasoline Engines 15 05-27-2009 11:15:55 PM
