Another Twin City
this thread has 162 replies and has been viewed 18454 times
Old 11-28-2016, 10:09:06 AM
Russ Hamm's Avatar
Images: 1
Default Re: Another Twin City
Uncle Dan said that the original owner used this tractor for belt work on the silage blower after it was retired from field work, sounded like this was its job for many years.
There are grease zerks that go to the cross shaft bearings, might have been owner installed, with long tubes that look like it could be greased while its running.
Old 12-05-2016, 11:16:18 PM
Hi Russ...hope the work on your Twin City is going smoothly. I just got my new oil strainer for the TC 20-35 from McMaster-Carr and thought you might be interested as this one fits the 17-28 as well. It has a 30 mesh pleated stainless screen for more filtering area than the original and has the correct 1 1/4 x 3/4 fitting attached for a screw-in replacement. This works out well for non-soldering types like myself.
Cost is about $20 plus shipping.
Name:	TC 20-35 Canadian 377.jpg
ID:	269593   Click image for larger version
Name:	TC 20-35 Canadian 378.jpg
The Following 4 Users Say Thank You to Mark Schneider For This Post:
  #53
Old 12-06-2016, 10:31:46 AM
Russ Hamm's Avatar
Images: 1
Thanks Mark, i'll check today on ordering, got two bearings coming for the fan drive shaft and input shaft thanks to you also.
Just yesterday morning i heard the news that an old local collector passed away last weekend. When my uncle bought this 17-28 he also bought a large TC/MM on steel from the same owners' auction. I always remembered it as a much larger tractor than the 17-28 with wide rear wheels.
Anyway, this fellow recently passed had bought that tractor from uncle Dan some years ago, and i heard he still had it. I remember the exhause was open back then, i'm sure the engine was very rough.
Gleaner will know this fellow as Willard H, had a lot of tractors and etc.
The Following 2 Users Say Thank You to Russ Hamm For This Post:
  #54
Old 12-06-2016, 08:56:00 PM
Russ...that sounds interesting about the potential lead on the Big Twin Cam. Keep us posted.
If another clutch center disc doesn't show up I'm pretty sure that yours can be redrilled. I'll bet someone with a Bridgeport and some kind of indexing head could figure out how to do it.
The Following User Says Thank You to Mark Schneider For This Post:
  #55
Old 12-06-2016, 09:24:47 PM
Phil Johnson's Avatar
Russ, if three of those holes are not too far out of round, you might bore them out to true them up and then press brass or steel bushings in them to remove the excess play.
  #56
Old 12-07-2016, 09:49:51 AM
Russ Hamm's Avatar
Images: 1
I may just do that, wondered if boring and bushing took away too much material but i don't think so. Since it has been re-drilled already the second set of holes isn't real bad, may try it.
Does anyone have access to facings? These are abount an eighth inch but sure don't want to take it apart again.
---------- Post added at 09:49:51 AM ---------- Previous post was at 09:48:25 AM ----------
Whatever supplier our parts guy called said we got the last one of those screens they had.
Old 12-09-2016, 12:26:58 AM
Russ Hamm's Avatar
Images: 1
I was able to do some more dissasembly this evening. The rod bearings look good, i was surprised as no rings were stuck. The wrist pin bushings have a little play, nothing serious, i was surprised to find none of the rings were stuck. At some time one of the rod bolt nuts must have been misplaced and someone put two shallow nuts in place of the original deep one, possibly the Chevrolet garage that overhauled it in 1940.
The cam gears are good, but the idler gear from the crank to cam gears is worn pretty good, still, i think if i can't come up with a better one it will still work. I would feel better replacing it if possible.
The oil pump looks good, although the half moon keys need replaced. The key on the fan drive/governor shaft gave a good fight, had to be heated and cooled before it came out.
ID:	269813   Click image for larger version
ID:	269814   Click image for larger version
ID:	269815   Click image for larger version
The Following 6 Users Say Thank You to Russ Hamm For This Post:
  #58
Old 12-09-2016, 12:33:31 AM
Russ Hamm's Avatar
Images: 1
More pics, looks like re-assembly on the head and honing out the cylinders will be next.
ID:	269817   Click image for larger version
The Following 7 Users Say Thank You to Russ Hamm For This Post:
  #59
Old 12-09-2016, 11:38:21 AM
Nebraska Kirk Nebraska Kirk is offline
That idler gear is not too bad, Russ, I would not be afraid to continue using it. The idler gear on my 17-28 is worn so bad the teeth are sharp enough to shave with!! When I get around to rebuilding it I am going to make a new gear.
The Following User Says Thank You to Nebraska Kirk For This Post:
  #60
Old 12-09-2016, 12:28:55 PM
Russ Hamm's Avatar
Images: 1
What do you guys think of drilling six more holes in that driven disc? I'm just thinking of six to keep it somewhat balanced as it has six in it already.
I have a lead on one with only three that needs re-drilled if i would just wait, which i sure have time before the engine is ready.
Twin City 17-28...My Intiation into the Twin Cam Faternity! Mark Schneider Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 120 06-01-2018 09:21:55 AM
Twin City Big Twin Cam up for Sale Mark Schneider Live Auctions of Engines, Tractors and Old Iron 27 03-19-2017 10:58:08 PM
Twin City KTA ozfarm Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 12-29-2013 11:12:27 PM
Twin City 12-20 Pat Bayer Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 20 06-10-2012 11:02:28 PM
MM Twin City JTS DavidRaines Antique Farm Tractors 3 05-10-2008 11:02:19 AM
