Go Back   SmokStak > SmokStak® Antique Engine Community > Multi-Cylinder Stationary Gasoline Engines and Power Units
Multi-Cylinder Stationary Gasoline Engines and Power Units Waukesha, Buda, Climax, LeRoi and others.
Help identifying this engine and its use in John Deere equipment?
this thread has 9 replies and has been viewed 3321 times
Old 06-02-2013, 12:36:16 PM
keithf keithf is offline
Default Help identifying this engine and its use in John Deere equipment?
Hello experts, any thoughts on what this is and what piece of John Deere equipment it might have come off of - seller says it's a 4 cylinder gas engine - no other info available.
Thank you!
Name:	old JD engine pic.jpg
The Following User Says Thank You to keithf For This Post:
Old 06-02-2013, 12:39:58 PM
Default Re: Help identifying this engine and its use in John Deere equipment?
My guess a model HA 92. (92 cubic inches) Used on model 30 combines. If I am correct Deere discontinued parts for them a long time ago.
The Following User Says Thank You to John Schwiebert For This Post:
Old 06-02-2013, 03:39:19 PM
Looks like a John Deere L Power unit to me.these are the same engine used in the later or styled L series John deere tractors L,LA,LI.John
Old 06-02-2013, 06:56:08 PM
coyote62ny coyote62ny is offline
looks like a john deere power unit off of a 12a combine. if it is off a 12a combine it will be a two cylinder engine
The Following User Says Thank You to coyote62ny For This Post:
Old 06-02-2013, 06:59:40 PM
MoRo's Avatar
MoRo MoRo is offline
Might be a later power unit, if an L-series. Ours didn't have electric start and the oil pressure guage was in a different place. I believe our 12A was a 1946.
The Following User Says Thank You to MoRo For This Post:
Old 06-02-2013, 07:11:50 PM
He said it was a FOUR cylinder! Look at the intake manifold and the fuel pump!
Old 06-02-2013, 08:53:16 PM
Hello, thank you for all the replies. I am going to pass on purchasing it.
If you are interested it is on Dallas craigslist - search for old john deere motor.
Thank you again! Keith.
Old 06-02-2013, 08:58:28 PM
HBurk HBurk is offline
John,
Some of us can't read very well, can we?
The Following User Says Thank You to HBurk For This Post:
Old 06-04-2013, 05:21:12 PM
Dempster Dempster is offline
Keith, The HA-92 John Deere engine 4 cylinder usually used a Wico model X vertical, XVD-2330 vertical dist mount type magneto. As said the pull type JD 30 combines, possibly some JD hay balers & some were sold for just general power unit use. Should have a tag on the engine someplace. Some others that used a different Wico mag or Delco battery distributor were TA-92, TB-92, TA-145, & early TA-217 power units. Later 217 units were different on 55 JD combines. There was also a EA-92 4 cyld JD power unit used on some but not all JD 114W & 116W hay balers. Other 114/w & 116W balers used the Wisconsin VF4D engines.
The Following User Says Thank You to Dempster For This Post:
Old 06-04-2013, 06:23:54 PM
Thank you Dempster!
John Deere model E Engine, Little John niceonetidy Scale Model Engineering 5 11-01-2012 07:36:24 AM
John Deere & John Deere Bain horse drawn mowers Amosalmo Horse Drawn Equipment 4 05-18-2012 11:35:01 AM
M John Deere Farm Equipment hoppy Antique Farm Tractors 9 05-08-2011 01:57:38 PM
Need help identifying JI Case equipment jarrottd Farm Antiques and Collectibles 2 11-04-2010 11:30:26 PM
John Deere Equipment Info? Andy Albrecht Antique Engine Archives 1 05-25-2003 12:51:52 PM
