Automatic Voltage Regulators
this thread has 33 replies and has been viewed 2711 times
Old 05-06-2018, 08:43:41 PM
Vanman Vanman is offline
Default Re: Automatic Voltage Regulators
Funny thing about the little neon lamps. I hadn't seen one blow up, but, knowing their characteristics, I had my suspicions.
So, when a friend was getting ready to plug one in, he noticed that I was backing up lol. He said, "what?". I just grinned and said, "Plug it in and see!". We were both pleasantly surprised by the magnitude of the POP!
Old 05-06-2018, 11:49:02 PM
Yah, figure that quarter ohm ionized resistance across 120VAC RMS works out to just over 21 Amps or about 1800 Watts* concentrated inside that little glass envelope. That rather suddenly increases the gas pressure inside the bulb.... not to mention the arc that contnues to discharge between the poles until they get blown far enough apart for the ionization of just the inrush atmosphere to fall off after the neon scatters.
The way I knew they would blow up you could easily guess....
Doc
*~170V P-P /2 = ~85V peak per half cycle
"The time has come," the Walrus said, "To talk of many things: Of shoes--and ships--and sealing-wax--Of cabbages--and kings"
Old 05-07-2018, 05:16:45 AM
Elden DuRand's Avatar
Images: 11
Since I'm definitely not an expert on gensets, I thought I'd jump-in here with my non-expertise.
If an engineer designs a voltage regulator that would self destruct during an ordinary event (genset stopping while under load - running out of fuel), he should be re-tasked with sweeping the parking lot.
Intermittent brushes, dirty commutators and slip rings, uneven loads, etc. should also be considered when designing the regulator.
In other words, it isn't rocket science to design and build a robust voltage regulator, whether it be for a DC supply or a genset.
Maybe the bean counters are getting into the act.
Oh, yes - the NE-2 lamps used as surge suppressors work well as long as the energy they dissipate is small. Varistors are the choice today.
Take care - Elden
http://www.eldensengines.com
Old 05-07-2018, 06:24:26 AM
armandh armandh is offline
that post #6 reference left the building I add it here
ID:	309884   Click image for larger version
by using this free advise, you, your heirs, etc
absolve, save, and hold harmless the advisor.
CAVEAT EMPTOR
YMMV
The Following 3 Users Say Thank You to armandh For This Post:
Old 05-07-2018, 06:31:03 AM
getting outside the closed loop
VR and slip ring problems are simple [IMHO]
my take on this
first engine start in a while....
load goes on voltage goes down,
sensed by VR which increases voltage to the field
tarnished slip rings prevent increase in field current
causing the VR output to go max
tarnish is worn off and load slaps on the maxed output
sudden current exceeds component rating
magic smoke escapes
CAVEAT EMPTOR
YMMV
Old 05-07-2018, 06:45:20 AM
My entry for a bullit proof AVR design. Assumes ground referenced aux supply rectified and positive fed to other side of field. Transformer primary is wired to select 120 or 240 input. Trimmers set 1 VAC into RMS converter and internal reference to set output. Transistors are thermally linked on heatsink. If output overheats LM395 automatically shuts down. Only assembly difficulty is RMS converter ONLY available in tiny little surface mount dip package.
Doc
The Following 2 Users Say Thank You to Thaumaturge For This Post:
Old 05-07-2018, 06:35:22 PM
Images: 11
Originally Posted by armandh View Post
that reference left the building I add it here
Ahh, yes! I remember well the Signetics Write Only Memory. They ran ads in some of the engineering rags and actually garnered some interest.
It was a good joke!
Take care - Elden
Old 05-07-2018, 07:15:55 PM
I think the ad ran in 4-1-1973 editions
CAVEAT EMPTOR
YMMV
Old 05-07-2018, 11:07:42 PM
Zeromedic Zeromedic is offline
On the same level as multi-pass floppy disk compression.
Write only memory was the ultimate /dev/null
ID:	309979   Click image for larger version
The Following User Says Thank You to Zeromedic For This Post:
Old 05-09-2018, 03:03:35 AM
(Stubornly sticking to AVR sbject.....)
A few explanations about my AVR design. (Schematic in post #16.)
The transformer; Nothing really special. A little 25va PCB mount will work fine. Dual primary only chosen to give option of sensing either 120 or 240 outputs. But a single primary model of proper voltage will do fine. Note that secondary probably DOES need to be a 12.6 Volt Center tapped, not a 12.0. Reason for that is to feed as high a voltage as possible to the local +/- power supplies. As it is the 5.1 volt zeners are probably not needed, but will serve as clamps for any spikes that might get to them.
Supply voltages will normally be around 4.5 volts or so. Even so that should be quite adequate. The LM10 output will swing within 15mV of rails. Only needs to swing a few volts to turn on LM395.
The LTC1966 was chosen for RMS converter simply for least parts requirement and 1VAC input/1VDC output. AD736 would probably work okay, but only has 200mV input / output. This changes both input and reference scaling.
Initial calibration: Check line voltage with a good true RMS meter. Plug transformer primary into AC line outlet. Connect meter black lead to C1 - terminal. Adjust R8 for 1VRMS at input of LTC1966 with 120VAC on primary. (U2 RMS converter is TINY, so probably easier to measure at junction of R6, R7 & R9.) Should now read 1VDC at U2 output (C1 + lead). Probe pin 1 of U1 (LM10CN) and adjust R4 for 1VDC.
You're done. Install and adj R4 for proper output. (R8 is set once and forget.)
Now... the MAIN reason anybody might bother with this design.... Cheap and pretty much bullit proof! You can buy ALL the parts for $30-$40. If constructed correctly, circuit should protect itself. Q2 LM395 has built in thermal protection. Thermally bonding Q1 to Q2 uses thermal shutdown to protect output. Q1 2SC5200 is rated for about double typical field current and ten times the likely voltage. The back EMF protection diode is way overkill. (Second choice 1N5408, 3A 1000V PIV.)
SO.... COMMENTS?
Doc
Question about older voltage regulators Nazrat Onan Generators 11 04-24-2016 11:21:03 AM
china made voltage regulators any good? YellowLister Onan Generators 19 01-07-2016 05:00:39 PM
What does the REACTOR do on JB and JC late voltage regulators? Motorhead Onan Generators 13 12-10-2015 07:50:34 AM
Feedback on import automatic voltage regulators, like the sx460 CougarMountain Military MEP and Aircraft Gen-Sets 5 08-05-2013 09:04:23 PM
Onan BFG Voltage Regulators? threejeeps Onan Generators 1 05-25-2013 03:03:26 PM
