4 Cylinder Air Cooled Delco
this thread has 26 replies and has been viewed 2668 times
Old 01-08-2018, 07:33:09 PM
Dale Burkman Dale Burkman is offline
Default Re: 4 Cylinder Air Cooled Delco
As Group44XJS said 32 volt units used coil ignition. The 110 volt units were magneto fired. The 32 volt model numbers were 15C3 and 15C33. looks like both of yours are 32 volt.
The Following User Says Thank You to Dale Burkman For This Post:
Old 01-09-2018, 07:38:56 AM
GeneratorGus's Avatar
GeneratorGus GeneratorGus is offline
If it is 110 DC, a normal battery set would be 55-2 volt individual lead acid cells, plus 4 or 5 reserve cells. In the day, 110V units were nearly twice the price of 32V because of the number of cells to make up the battery.
Your 12 volt car battery has 6 cells.
But that doesn't mean you need an entire bank of batteries to start it. I have a large Lister 110V genset (See my avatar) that I start with 3 lawn & garden batteries, or you can hand crank. Just disconnect when it starts to fire up. Either method will require a magneto or an isolated ignition set up.
At that point you can run any 110 DC appliance or anything with a universal motor. Regular "old style" incandescent light bulbs or an electric heater if it doesn't have a non-universal fan setup.
Attached is a page from a 1927 Graybar (Western Electric) catalogue showing battery prices.
GUS
The Following 3 Users Say Thank You to GeneratorGus For This Post:
Old 01-09-2018, 12:52:15 PM
turbo turbo is offline
I guess some things have never changed, batteries always have been and always will be EXPENSIVE!!
Old 01-09-2018, 01:33:12 PM
Vanman Vanman is offline
The 140 volt Kohler used 56 cells for a nominal system voltage of 112. A normal operating range would likely be 108 ~ 120. Though I'd expect that the voltage would seldom exceed ~130 during charging, I have always wondered what, if anything, was done to protect the lamps at the higher voltage encountered during charging. Tapping the battery is not a viable option, unless special care is taken to charge the extra cells individually.
Old 01-09-2018, 02:29:32 PM
Email NOT Working
If we used today's typical off grid settings that many cells would bulk charge at 136 volts.
Old 01-13-2018, 02:33:58 AM
Steve Wright's Avatar
Steve Wright Steve Wright is offline
Images: 2
Here is mine.
Name:	2003B pix 248.jpg
ID:	300319   Click image for larger version
Name:	2003B pix 252.jpg
ID:	300320   Click image for larger version
Name:	2003B pix 543.jpg
The Following 4 Users Say Thank You to Steve Wright For This Post:
Old 01-13-2018, 03:29:52 AM
That's a beautiful machine there, Steve!
It seems that in the "old days" cells were charged to an even higher voltage of 2-1/2. So from standard nominal battery voltages of 6, 12, 32, and 112, generator voltages of 7-1/2, 15, 40, and 140 result.
Keith
Old 02-22-2018, 10:32:46 PM
I thought I would give a little update. Sorry for the delay, I have been busy at work lately. I disassembled and inspected a month ago and determined it needed new rings, rod bushings and valve guides.
ID:	303863   Click image for larger version
ID:	303864   Click image for larger version
Old 02-22-2018, 10:37:25 PM
The unusual overflow carb. and making new valve guides.
ID:	303866   Click image for larger version
ID:	303867   Click image for larger version
ID:	303868   Click image for larger version
Old 02-22-2018, 10:41:16 PM
Making new valve guides. It has an unusual valve guide where it is a blind hole and the guide is driven in and seats about a half inch from the bottom of the head. The original guids were made from some type of fiber material.
ID:	303870   Click image for larger version
ID:	303871   Click image for larger version
The Following 2 Users Say Thank You to turbo For This Post:
Delco 8GW3 Water Cooled Engine-Generator M Schwab Generators & Electric Motors General Discussion 1 10-19-2013 08:55:06 AM
Delco Light water cooled marine plant FDChief Delco and other Low Voltage DC Light Plants 0 10-13-2013 12:07:39 PM
Caron Bros. & Delco water cooled nar Antique Gas Engine Discussion 3 05-03-2009 12:21:18 AM
Delco water cooled help nar Generators & Electric Motors General Discussion 4 07-29-2008 12:26:53 AM
Four Cylinder Copper-Cooled Delco Benjamin Roth Generators & Electric Motors General Discussion 8 04-02-2008 11:44:24 PM
