Induction Motor Production Line
this thread has 4 replies and has been viewed 867 times
Old 04-10-2018, 10:29:55 PM
Default Induction Motor Production Line
The way the windings are inserted into the stator looks a little brutal to me.
Considering a lot of the china stuff uses aluminum wire and the rather thin layers of varnish.
https://www.youtube.com/watch?v=02VMfMml4iU
Robert
The Following User Says Thank You to Railroads For This Post:
Old 04-11-2018, 01:21:30 AM
Vanman Vanman is offline
Default Re: Induction Motor Production Line
From what I've seen that seems to be a standard construction method, at least for the smaller sizes. Remember that the wire is protected from the steel by the slot liners. Interesting that the testing station has a shield that covers the unit under test.
Old 04-11-2018, 08:48:20 PM
Newoldstock Newoldstock is offline
My first job was rewinding motors.
We did that all by hand with no machines.
It was hard on the back sitting at a bench all day making the wires nest and forming the coils.
This is deskilled work.
You don't even have to understand what you are doing.
Cheaper to buy new than repair now.
---------- Post added at 08:48:20 PM ---------- Previous post was at 08:32:14 PM ----------
This video in Hindi shows some skill.
I am really impressed with how well this was done and even if you do not speak the language it is informative.
An unusual single coil single slot winding design. ( might be for space saving )
2 pole 3000 rpm motor about 1/2 hp by eyeball.
Winding is called a lap and the reason all the coils are lifted and then put back in is to make it what's called span down.
Because of the size it would be harder ( but no impossible to do ) span up and uglier.
A smarter way would have been to use a concentric coil lay out.
These guys might not have the technical skill to convert the winding to concentric.
However it still shows skill and patients to do.
https://www.youtube.com/playlist?lis...AhWEUc7QCFfcUw
The Following 2 Users Say Thank You to Newoldstock For This Post:
Old 04-11-2018, 09:59:52 PM
There was one other expedient way to make a winding you never see anymore.
I think it was called a Skewn coil used by electricians in the early days to rewind the crude low density machines
You made one big coil for each coil group and laid it in the widest span, then put a twist in and laid it in the next inner set.
This made a sort of concentric coil group.
The old fellow that trained me used navy electric motor/generator manuals for field service, I think that's where I learned most of the practical part from ( that and hands on training and direction from the boss )
Best practical training still comes from the military field manuals of years past, there is not a lot of books on the subject printed today because machine wound motors and generators have taken over.
That's a warning to us all in regards to skills that require patients and trained hands.
Use it, teach it or lose it ( I probably lost it for all purposes other than watching and commenting )
The Following User Says Thank You to Newoldstock For This Post:
Old 04-12-2018, 01:32:31 AM
I'll have to look into some of my antique machines and see how they might be wound...
How will the uF of an AC induction motor capacitor affect the torque of the motor? realflow100 Generators & Electric Motors General Discussion 6 05-27-2015 01:21:35 PM
25 HP Induction motor JIMnWV Generators & Electric Motors General Discussion 22 11-28-2014 08:12:57 PM
Westinghouse 1.5 induction motor help (compressor motor) eeprete Generators & Electric Motors General Discussion 20 10-30-2014 04:41:22 PM
1915 Induction Motor Fred Berry Generators & Electric Motors General Discussion 1 01-30-2010 03:23:16 PM
FairbanksMorse Induction Motor VicP Generators & Electric Motors General Discussion 1 07-15-2007 05:27:08 PM
