Correct Oil for Cat V8 Natural Gas Generator
this thread has 11 replies and has been viewed 1168 times
Old 06-15-2018, 02:37:13 PM
JeffK's Avatar
JeffK JeffK is offline
Images: 11
Default Correct Oil for Cat V8 Natural Gas Generator
We have a 20 year old Cat v8 natural gas generator. We are ready to change the oil again and was wondering if itís special cat oil or 40 weight
Idle hands are the devils workshop
Old 06-15-2018, 03:43:54 PM
Default Re: Correct oil
My guess is that it is a bit different than commonly available SAE 40 oil. Here is more than you want to know about lubricating oil for natural gas fueled engines.
https://www.machinerylubrication.com...e-oil-analysis
Old 06-15-2018, 04:02:26 PM
When you say Cat V8 generator, are we talking like an Olympian that has a Chevy or Ford V8, probably 150kw or less, or a larger set based off of a Cat diesel engine?
Most of the Chevy/Ford V8's are living on whatever your favorite 15-40 'diesel' oil is, and doing fine. (Rotella, Delo, Napa, Whatever brand you like)
Old 06-15-2018, 04:05:27 PM
Good point. I assumed a larger set, based on the oil container.
Old 06-15-2018, 05:21:45 PM
JeffK's Avatar
Images: 11
Default Re: Correct Oil for Cat V8 Natural Gas Generator
Itís a 300 kw. The people at The bulkpetroleum said SAE 40 is fine.
We have been getting the CAT brand oil but are looking to save a few scheckels
Old 06-15-2018, 05:27:02 PM
Nothing special about Cat oil. Just comes in a yellow bucket with a higher price.
That being said, you may need one of the specialty natural gas engine oils. Just any ol' 40w may be a bad idea.
The Following User Says Thank You to pegasuspinto For This Post:
Old 06-15-2018, 09:59:51 PM
With all due respect - I advise caution when trying to economize where engine oil is concerned. One oil related failure will easily cost many times more than the difference in cost between a premium quality oil and a "less expensive" oil.
The Following 2 Users Say Thank You to Wayne 440 For This Post:
Old 06-15-2018, 10:11:42 PM
s100 s100 is offline
Wayne 440 beat me to what I was going to say but good advice is worth repeating. Skimping on oil is a poor way to save money. If the CAT oil is really pricey and you want to save but be smart about it, I would contact CAT directly. Tell 'em the model and serial number of your genset and ask them which oils they can recommend, besides their own. They should be able to give you some concrete recommendations. And be careful if they say something like "...any oil that meets spec xxxxx.zz.." There are many ways of testing oils, and many ways of interpreting the results AND the standards they must meet. This is NOT a clear cut and absolutely objective process. If they won't give you a specific Shell or Pennzoil or Kendall or other name brand product concede defeat and keep paying for the CAT oil. Your bean counter may hate you but your engine will love you for it.
The Following User Says Thank You to s100 For This Post:
Old 06-16-2018, 12:57:15 AM
Kimbra Dean Kimbra Dean is offline
UhWe have a Cat G3412 where I work. We use Mobil Pegasus 15W 40 natural gas engine oil.
The Following User Says Thank You to Kimbra Dean For This Post:
Old 06-21-2018, 07:26:11 AM
JeffK's Avatar
Images: 11
I have the data sheet for the cat oil and the Miles petroleum replacement, I am not sure if itís a close enough match. Here are the data sheets
ID:	312817   Click image for larger version
Generator Not starting on Natural Gas sharp Generators & Electric Motors General Discussion 21 06-01-2018 05:21:02 PM
Natural Gas Generator BHoward Alternative Fuels 3 12-06-2017 05:23:33 PM
Natural gas supply to 20 Es generator GADavis Onan Generators 13 09-29-2014 01:54:49 PM
Wisconsin THD natural gas generator MXB Generators & Electric Motors General Discussion 9 04-24-2013 10:36:53 PM
natural gas generator bentley Generators & Electric Motors General Discussion 4 06-22-2004 04:31:41 AM
