Carbon Brush Connection - Glue or Cement
this thread has 23 replies and has been viewed 14125 times
Old 06-30-2008, 11:28:15 PM
Don Smith
Default Re: Carbon brush connection - Glue or Cement
You might try adding some copper filings to the conductive glue. Make the hole a bit larger than the lead and fold it over inside the hole. Make sure the hole is filled with the conductive glue when installing the lead. Since the carbon brush is also not real conductive the glue should work fine. Wash out the hole before adding the glue to remove any loose carbon dust. Don Smith
Old 07-01-2008, 12:44:01 PM
Fred M. Fred M. is offline
Originally Posted by Doogdoog View Post
I was thinking of sanding the brush down to size and drilling a hole to insert the braided copper wire.
Just how big are these brushes? Would it be practical to drill and tap them for a coarse-pitch screw, and use a crimp lug on the braid?
Fred
Old 07-02-2008, 04:21:50 AM
Doogdoog Doogdoog is offline
Aloha,
I have a lot of brushes of various sizes but the one I need to modify is small, less than 1/4" square. The brush is for a automobile window lift motor and I can't find any of these brushes around. Actually, I have a whole bucket full of carbon brushes but of the larger sizes. TIA
Mahalo,
doogdoog
Old 07-02-2008, 11:24:30 AM
Don Smith
My Local ACE Hardware has a collection of brushes for sale in their hardware section. They have a collection of parts drawers where you can find things like spacers, special nuts, "C" clips, toggle switches, and other special hardware assortments. Might find one there. I believe Home Depot also has the same type of collection of special hardware drawers. Don Smith
Old 07-02-2008, 05:31:34 PM
Aloha Don,
Yes, I have to check out ACE to see what they have. I remember in the old days, they had practically any spare part that was needed. Now, they only keep a small supply of parts but yes, it would be a good idea to check them out. TIA
Mahalo,
doogdoog
Old 07-02-2008, 07:10:31 PM
David C David C is offline
If there are any electrical (automotive) rebuilders around your area, they should be able to get some for you. I used to get small brushes for window motors and headlight motors out of ACE Houston several years ago when I was in the parts business.
David
Old 07-03-2008, 10:37:45 AM
Don Smith
If you cannot find any there email me the specs (meaurments) and I will try to find them. Would need length, width, thickness of the brush as well as the length of the lead and any information as to its material, type of unit it is used, etc. Don Smith
Old 07-03-2008, 08:33:44 PM
Jim18655 Jim18655 is offline
Almost sounds like it's about the size of a small power tool brush. Got any old drills around the shop?
Jim
Old 07-04-2008, 03:14:13 AM
Aloha,
Thanks for the replies and Don, I will have to measure the brush when I have access to it again and will let you know. Yes Jim, it looks like a small power tool brush but these are hard to find. I went to ACE hardware and asked the salesperson if they sold carbon brushes for an electric motor and she said I don't think we have paint brushes for that. LOL It's a minor thing but it's so sad that we cannot get parts like the old days (wow! I am old!). TIA
Mahalo,
doogdoog
Old 07-04-2008, 04:30:27 PM
Photo Re: Carbon brush connection - Glue or Cement
Aloha,
I found a brush that may fit from McMaster-Carr and it is a little pricey for the size 3/16" square X 1/2" long (not including shipping). It sells for $8.12 each but the braided wire is on the end and not on the side like the original (don't know if it will hit the sides of the motor). Anyone know of a cheaper place? TIA
Mahalo,
doogdoog
Radiator glue? Avery22x36 Multi-Cylinder Stationary Engines and Power Units 9 05-24-2012 12:21:05 AM
Lincoln SA-180 carbon brush holder & brushes ciggs Welding Shop 12 10-06-2010 03:34:59 PM
flat belt glue Bob N Antique Gas Engine Discussion 1 08-24-2009 12:14:19 PM
Carbon Collector Brush, AB-33 Magneto. Need to replace, How, Where? DerekC Antique Gas Engine Discussion 7 01-02-2008 10:41:08 PM
What glue to use??? Larry Evans Antique Gas Engine Discussion 6 07-25-2005 10:43:53 AM
