Wisconsin Engines
Wisconsin 4G4D Weak Spark: help!
this thread has 12 replies and has been viewed 668 times
Old 03-14-2018, 10:52:57 AM
Motorhead's Avatar
Motorhead Motorhead is online now
Default Re: Wisconsin 4G4D Weak Spark: help!
Originally Posted by Jeff6566 View Post
I currently have my switch wire going to the neg. on the coil.
If I change up the battery for positive ground, will I need to reverse the coil?
DON'T change your battery polarity! Disconnect the battery and just switch the leads on the back of the ammeter, reconnect the battery and it will read charge when running instead of discharge. If you switch battery polarity you will probably damage the alternator
My 1939 WILLYS Pickup.
Bought in 1971
Old 03-14-2018, 11:00:22 AM
DCamp DCamp is offline
If the valve is not stuck bad, I have gone in with an allen wrench and tapped gently on valves to free them. Be careful removing the head bolts, as Wisconsin's are noted to brake off. I have started mixing a little diesel fuel with my gas to help lube the valves. I find the gas today runs hotter than the old stuff. In real hot weather I will mix up to 30% fuel. It smokes a little but the engine sounds better and runs cooler.
Old 03-14-2018, 02:18:50 PM
Motorhead's Avatar
I use 50 to 1 - 2 stroke oil. Put about an ounce to two per gallon of fuel. I use the two stroke oil in my common rail, 5.9 Cummins in my Dodge Pickup when I tow because of the ultra low sulphur diesel fuel.
IF you have a stuck head bolt or even before you try to remove them, take a punch that has at least a 1/4 inch face on the end, put it on the CENTER of the head bolt hex and rap it a few times with a ball peen hammer. This sets a shock through the bolt and helps to brake it loose. Oil the threads when replacing the head bolts.
Bought in 1971
Pe-75 weak spark csareb Small Air Cooled Gasoline Engines 4 03-07-2017 06:38:45 PM
Spark weak? maybe? Darryl Boyd Maytag Engine Collectibles 9 04-29-2015 02:44:16 PM
Wisconsin, unknown twin, weak spark on one cylinder Cheddarpecker Magnetos, Ignition Coils and Spark Plugs 9 01-05-2012 07:36:04 PM
LB Mag weak spark Bill Schaller Antique Engine Archives 7 08-12-2004 07:33:41 PM
Weak spark - Help Nathan Antique Engine Archives 2 03-09-2000 02:32:34 PM
