Wisconsin Engines
Wisconsin VH4D Idler Gear Side Clearance
this thread has 3 replies and has been viewed 396 times
Old 03-16-2018, 05:27:12 PM
Ben S. Ben S. is offline
Default Wisconsin VH4D Idler Gear Side Clearance
On re-installation of the idler gear on my VH4D the manual states "Maintain .003 to .004 inch clearance between idler gear and shoulder of shaft". I'm not really understanding this, I pressed the shaft back in (gently) and obviously the more you seat it the tighter the bearings would be. Where is the measurement taken? Does it mean perceptable slop in the gear? Any help would be appreciated - I've seen pictures of when this gear fails and I dont want to experience that!
Old 03-16-2018, 05:38:19 PM
Default Re: Wisconsin VH4D Idler gear side clearance
Slip a .004 feeler between the shoulder of the shaft that holds the gear on. It's usually a tight press on the shaft so getting that .004 will require some judicious tapping on the shaft. Yes it's that easy then lock down the set screws.
Old 03-16-2018, 07:02:32 PM
Guess I'm overthinking it, I'll look at it tomorrow. Thanks for the help!
Old 03-16-2018, 08:48:56 PM
Easy peasy. You'll be done with it in one minute and it's good for the next forty years. Got it too tight? Just slide hammer it out a bit and try it again. Been there done that.
Rumely 6A Idler Gear dndkorn Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 02-14-2018 08:16:41 PM
Wisconsin VH4D timing idler gear removal bfarroo Wisconsin Engines 8 09-01-2015 08:27:52 PM
VH4D idler gear failure and questions Hashtag Wisconsin Engines 5 12-15-2013 12:24:47 AM
Wisconsin VH4D Idler Gear LTVKID8x8 Wisconsin Engines 1 09-30-2012 11:38:13 PM
Wisconsin VG4 Idler stud/gear? kolo Wisconsin Engines 2 03-27-2012 08:56:16 AM
