Splitdorf on 10-20
this thread has 7 replies and has been viewed 596 times
Old 01-09-2019, 03:57:52 PM
g2contender g2contender is offline
Default Splitdorf on 10-20
Can anyone give me any info on this Splitdorf mag on a 10-20 that I am buying? Just want to learn before I take delivery. Would love to pick one up to take apart .
Thanks.
MIke
---------- Post added at 02:52:39 PM ---------- Previous post was at 02:51:27 PM ----------
Pics did not show.
---------- Post added at 02:56:24 PM ---------- Previous post was at 02:52:39 PM ----------
---------- Post added at 02:57:52 PM ---------- Previous post was at 02:56:24 PM ----------
The Following User Says Thank You to g2contender For This Post:
Old 01-09-2019, 04:44:27 PM
Russ Hamm's Avatar
Images: 1
Default Re: Splitdorf on 10-20
When you have a good Splitdorf in my opinion, you have the world by the coattails. I really like those mags, but if you have to work on it send it to a professional, I worked on several and broke pieces. When you start it, has a lever to flip by the coupler to engage the impulse, if it fires and dies you may have to flip it again as it will kick out at rpm. This is the same procedure on an E4A magneto, and it should retard with the arm up same.
Old 01-09-2019, 04:52:21 PM
Titan1020 Titan1020 is offline
Like Russ Hamm said these are great mags when they are hot. Points and condensers are unavailable. You have to substitute a modern capacitor to replace the original if its bad. The points usually can be filed an cleansed to make them useable again. That said this must be an earlier 10-20 since it is equipped with this Dixie and has no oil filter. Looks like a nice tractor.
The Following User Says Thank You to Titan1020 For This Post:
Old 01-09-2019, 05:41:40 PM
Can the splitdorf mag be swapped out for the E4A? Is that possible on these tractors?
Old 01-09-2019, 08:25:24 PM
Russ Hamm's Avatar
Images: 1
Originally Posted by casertractor View Post
Can the splitdorf mag be swaped out for the E4A?.Is that possible on these tractors?
Yes, it can. I think the coupler will even swap.
Old 01-09-2019, 08:43:19 PM
For repairs, Rudy Adrian is the man. He is a sponsor on here. Adrian's Magneto Service.
Old 01-09-2019, 09:01:12 PM
If you decide to swap
https://www.ebay.com/itm/Magneto-McC...-/153331037607
https://www.ebay.com/itm/Internation...75.c100623.m-1
Splitdorf type D mag Ray Cardoza Magnetos, Ignition Coils and Spark Plugs 0 11-12-2014 09:59:43 PM
Splitdorf Coil Jerry Magnetos, Ignition Coils and Spark Plugs 4 10-13-2014 11:22:54 PM
Splitdorf SS-O help Ed Noli Magnetos, Ignition Coils and Spark Plugs 0 01-15-2012 06:03:14 PM
Splitdorf ID Help John Derby Magnetos, Ignition Coils and Spark Plugs 0 06-04-2010 06:30:42 PM
Splitdorf model H FarmSC Magnetos, Ignition Coils and Spark Plugs 2 12-18-2007 12:04:06 PM
