WK40 Mccormick - how many are out there?
this thread has 146 replies and has been viewed 28882 times
Old 04-01-2013, 10:55:41 PM
Default Re: WK40 Mccormick - how many are out there ?
Originally Posted by AUSSIE TD-40 View Post
that looks like you will get some good parts, on factory rubber wheels, is it a 4 speed?
G'day Jake. Yes it has a 4 speed transmission. The tractor was lacking rear rims and a drawbar along with other small misc. I'm hoping to locate a factory swinging drawbar some day.
Are the WK-40's fairly common in Australia? I find the older Chamberlain's very interesting especially the models with Detroit power.
The Following User Says Thank You to Mark Schneider For This Post:
Old 04-02-2013, 07:15:02 AM
AUSSIE TD-40 AUSSIE TD-40 is offline
yes there are a few Wk-40's here, I have #6318 a 3 speed, I do see more WD-40's tho. Never seen a gasoline model till I went to the USA.
Most 40's here are 3 speeds, not sure why. Just got a Delco 6V starter for mine.
Jake.
The Following User Says Thank You to AUSSIE TD-40 For This Post:
  #43
Old 04-04-2013, 09:56:42 PM
Originally Posted by Mark Schneider View Post
The front half of the W-40 water pump closely resembles the one used on the Farmall M's. I'm wondering if the double pulley off the M pump would fit on the W-40 pump.
Lee and I have been doing a little research into the water pump pulley issue. Because it is a direct descendent of the W-40 we decided to get a water pump off a W-9 instead and compare the pulleys. Lee located one at Pete's Tractor Salvage in Anamoose ND and brought it over.
Check out the pictures. It looks like the W-9 pulley will fit right on the W-40 pump. Will know for sure when we try and make the switch.
Name:	Dads pictures 1.jpg
ID:	162058   Click image for larger version
Name:	Dads pictures 6.jpg
ID:	162059   Click image for larger version
Name:	Dads pictures 7.jpg
The Following 3 Users Say Thank You to Mark Schneider For This Post:
  #44
Old 04-08-2013, 02:58:38 PM
1206SWMO 1206SWMO is offline
I own the following WK-40 McCormicks..
WKC-4460
WKC-4462
I wonder if #4461 is still around..The one WK has 16.9x34's on it..It also has a gas manifold and a TA-40 crawler hood..
The Wards 32" rear tire on the other one blew out not long after getting it..
Back 35 years ago there were a bunch of WK-40's in my part of the country..I once owned (3) WK-40's,(2) WD-40,s,(1) WA-40,and (1) W-40 4 speed..
The Following 6 Users Say Thank You to 1206SWMO For This Post:
  #45
Old 04-13-2013, 08:19:24 PM
The W-9 double pulley water pump fan hub and pulley flange will fit right on a W-40 water pump housing. Except for the housings and impellers all other parts interchange. There is no part number or description for the double pulley fan hub in the W-40 (TC-19) parts book. It was only available as a complete water pump unit for the electric start option.
Here is how the part numbers shake out:
2369 D......W-40 pulley hub
2370 D......W-40 pulley flange
2370 DA....W-9 pulley flange
???????.....W-9 pulley hub. I found it very strange that there was no part number on this hub. Maybe someone out there with a W-9 parts book will chime in to supply one.
ID:	162768   Click image for larger version
  #46
Old 04-13-2013, 08:42:01 PM
Nebraska Kirk Nebraska Kirk is offline
The only other part my parts book (TC-32, W9/WD9) lists is #8023x, fan & generator pulley hub with oil seal.
The Following User Says Thank You to Nebraska Kirk For This Post:
  #47
Old 04-13-2013, 09:03:53 PM
Eric Best's Avatar
Eric Best Eric Best is offline
Note that 2369D is also in parts books TC-33 (O6, W6, OD-6, WD-6) and TC-25 (T14 and TD-14). If it fits, it fits, is probably the best answer.
Old 04-13-2013, 10:51:31 PM
carl wagner carl wagner is offline
I know the location of this WK 40. SN 4421. What year is this and what's it worth. Missing mag and needs manifold. Motor is loose.
ID:	162778   Click image for larger version
Old 04-14-2013, 12:06:12 AM
1936 I would say
others like Eric will know for sure
Jake.
  #50
Old 04-14-2013, 12:40:59 PM
smtwins smtwins is offline
I know a guy that has a spare block and head and ect. Email me and I will put you in contact. Hope this will help someone.
McCormick LA/LB Old Kansas Carburetors, Mixers, Fuel Pumps and fuel delivery 1 04-09-2017 12:49:54 PM
W12 McCormick Chester Antique Farm Tractors 2 03-18-2014 09:41:46 AM
parts wanted for wk40 jamie davey Antique Farm Tractors 2 07-19-2006 10:55:41 PM
1-1/2 hp McCormick M Bill Antique Engine Archives 2 07-30-2004 07:47:03 AM
McCormick M Tanner Remillard Antique Engine Archives 4 03-11-2002 01:59:39 AM
