Rumely 2040 G Restoration
this thread has 57 replies and has been viewed 9967 times
Old 01-12-2017, 06:22:24 PM
19-65Port 19-65Port is offline
Default Re: Rumely 2040 G Restoration
Make sure you put enough clearance in the bores or you will be doing this again. If you use the automotive formula, you will lock the engine up again. Check the oil cooling pump for proper circulation, air can get drawn in around the oil pump shaft and cause cavation which leads to overheating. Gasoline will not cause this issue, old tale. The higher the octane cooler the combustion. Use 2 cycle oil for upper end lube, it actually works great for this.
The Following 2 Users Say Thank You to 19-65Port For This Post:
Old 01-13-2017, 04:20:35 PM
lukeste lukeste is offline
Images: 1
we decided to go with .011 clearance. the side that got tight had .007 clearance at the bottom of the bore, the other side had .008. this tractor, although being under a restoration, will be used for plowing, threshing, etc. not so many hours per year but she needs to work well when called upon. there may be many opinions on what one thinks clearance should be, but this is what we are doing.
The Following User Says Thank You to lukeste For This Post:
  #23
Old 01-13-2017, 04:44:40 PM
Whether or not it makes any difference we went with .008" for a 16-30.
Those things run hot so piston expansion is more of an issue.
  #24
Old 09-15-2018, 06:58:39 PM
Images: 1
Stort of on a spur of the moment, decided to try and blast prime and paint main chassis. Maybe fronts soon too, but the rears will need the bulls taken off for some rivet work for both loose and missing rivets... and then... blast prime and paint rears. Any one have lugs around for a 2040? Be happy to get this done b4 winter and then I can assemble motor over the winter.i think it got 20 hours into steam washer on the frame and tinwork.
ID:	318814   Click image for larger version
ID:	318815   Click image for larger version
ID:	318816   Click image for larger version
The Following 10 Users Say Thank You to lukeste For This Post:
  #25
Old 09-15-2018, 09:33:07 PM
D Rutherford D Rutherford is offline
Hey Luke, looks like your becoming a Rumely Dealer! I love it and hope to see it someday!
The Following User Says Thank You to D Rutherford For This Post:
  #26
Old 09-15-2018, 10:07:19 PM
halcon halcon is offline
plowing at rollag. it was pulling like a bitch, and running strait gas.... got her too hot. lesson learned I guess.
Looking at those gears I would say that tractor is just not used to hard work.
The Following 3 Users Say Thank You to halcon For This Post:
  #27
Old 09-16-2018, 09:17:19 PM
Images: 1
The bounties of a long very hot day. Found the stamp in the frame and matched my serial tag.
ID:	318891   Click image for larger version
ID:	318892   Click image for larger version
ID:	318893   Click image for larger version
  #28
Old 09-16-2018, 10:50:29 PM
S.Simons S.Simons is offline
When do you want to start on my G ?
The Following 2 Users Say Thank You to S.Simons For This Post:
  #29
Old 09-17-2018, 11:50:50 AM
Images: 1
not any time soon!!
Old 09-18-2018, 08:15:38 AM
Images: 1
Transformation Tuesday. Looks dark to me but is dark in shop too will lighten when outside. Same custom mix as 1630 I have
ID:	318996   Click image for larger version
ID:	318997   Click image for larger version
The Following 9 Users Say Thank You to lukeste For This Post:
Rumely 12-20 Restoration lukeste Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 140 10-11-2015 10:58:44 PM
Restoration of Rumely # 6153 Jerred Ruble Steam Stationary Engines, Traction Engines, Steam Boats 25 10-22-2013 09:47:29 AM
WDM 16-30 Model H Rumely Restoration Western Development Museum Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 9 10-31-2012 10:24:08 PM
Rumely 30-60E-restoration help required.... jim burlingham Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 11-27-2011 11:54:37 PM
Rumely 25-40X Restoration, need parts Exmax Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 9 08-07-2010 06:11:34 PM
