Twin City small Tractors. "On a WHIM"
this thread has 242 replies and has been viewed 11146 times
Old 09-19-2018, 05:48:31 PM
Duey C Duey C is offline
Default Re: Twin City small Tractors. "On a WHIM"
I think I answered my own question. I read the book's description on removal of the column for the 23rd time then zoomed the drawing WAY in.
Now I see the fine threads on the column's lower bushing housing. I mean the FT-238 adjusting plug for steering worm/adjusting bearing for steering worm. It uses (2) 1/2 X 1-1/2 cap screws to clamp it to the column. It isn't really plain but the threads are there so I feel dumb right now.
The parts book is almost clear enough also. Good thing I'm not working on rockets this week. ie Rocket Science.
Now to loosen the column from the shaft. Oh boy.
The Following 5 Users Say Thank You to Duey C For This Post:
Old 09-20-2018, 09:30:54 PM
I feel better and less dumb today. I have the column out.
What the book left out is this old tractor’s shaft and column were stuck together and how to deal with that. :-) I’ve written a bunch of service bulletins in the past and I always had to pare the wording down to manageable levels or the bare minimum.
A pipe wrench on the STOUT column up at the (steel?) upper bushing and a 2X4 thru the wheel spoke against the column popped them loose. Mr. Fibro-Myalgia with a cracked rib got it done, just had to line everything up so I could deal with it. I stood on the ground at the back of the platform. Cake.
The pipe wrench is a Soo Line wrench I found on the highway right near their yard. They turned the corner and the wrench slid off the truck I figured. Darn right I spun my car around around and grabbed it! I needed a bigger pipe wrench!
Good grief is that assy HEAVY!
Need to find the right lighting to catch a pic of the makers stamping on the column tubing. Uff da! In-house? Feels good working with this stuff again.
I should also try resetting my camera. My pics turn out a bit small and low rez for me. Gotta try something else. :-) I’ll try it from my end this time.
On the other hand, I’m such a dunce, working on the steering and transmission when I should be prepping the engine to run again! An old friend says “You’ll have that.” :-)
FT-238 adjusto for the worm has 2-1/2“ - 12 threads by what my caliper says.
This pic is for the few that haven’t tore into these things. :-)
A crummy look down into the case. Look at the slim gear just to the right and the finals. He has been pulled really hard. Which gear is that? 1st?
The bevels look beautiful from what I can see.
This sliding/slop is almost a small mystery. The sector is trapped in its housing so perhaps the setscrew is loose if using that to try to retain the steering shaft. The FT-245 thrust collar is out of place and missing the big 5/16 x 3-1/2 cotter.
Question answered I think.
ID:	319190   Click image for larger version
ID:	319191   Click image for larger version
The Following 6 Users Say Thank You to Duey C For This Post:
  #73
Old 09-23-2018, 05:32:09 PM
Short side-step. Played with the oil filter today and find a cartridge I swear doesnít have the room to allow any oil around the outside to do any filtering...
I pushed it out with a big punch.
I should probably throw the old filter away but itís about the only TC/MM memorabilia I have! :-)
ID:	319380   Click image for larger version
ID:	319381   Click image for larger version
The Following User Says Thank You to Duey C For This Post:
  #74
Old 09-23-2018, 06:09:40 PM
Molinegb Molinegb is offline
Same filter as U,KTA,GB etc.KE5159 Some I have.
The Following 3 Users Say Thank You to Molinegb For This Post:
  #75
Old 09-23-2018, 07:43:37 PM
Hahaha! now that's memorabilia!
Thanks gb!
Hmmm, I wonder what Wix is providing these days... Oh NAPA, here I come again.
I walked out to the basket case MTA and sure enough. Thanks again. :-)
Old 09-23-2018, 09:05:10 PM
Gee, I wonder when replacing the steering column if I should’ve loosened the 2 adjusting screws for the steering sector bracket? Perhaps it would’ve “floated” a little easier to allow the 4 bolts in the steering support bracket to drop into place instead of me coercing the whole affair into place and then realizing it went bloop and it aligned up after I had three bolts started. Might’ve been easier to start the adjusting plug into those 2-1/2“ threads at the worm and sector bracket too.
Won’t be too far down the road and I’ll test my theories as I’ll need to rip it all apart again, find a sucker with arms as long as mine or longer to hang from the rafters upside down to be able to reach that far down into the case to install the bolt or 5/16 cotter in the shaft & collar. I still think what sidelined that tractor was a crash, a roll away or something that mucked up the radiator and sheared the 5/16x3-1/2 cotter pin out of the collar.
A couple of obligatory gear shots from the case. He’s pulled his heart out for the users.
ID:	319405   Click image for larger version
The Following 2 Users Say Thank You to Duey C For This Post:
  #77
Old 09-24-2018, 01:27:33 AM
The 21-32 is steering again for the time being! Just stuck and mucked up. I'm quite glad! No tractor racing for the moment tho...
Yet at another crossroad.
Tires: I think I'll see what the local GoodYear store has to offer for used 20 inch front tires.
Maw has "hinted" she ain't wanting me to spend any more moneys on these old tractors. We'll see. We are so dang cheap! Got $$ to play with but I could do this for a hundred instead of three for steel in front? So dang cheap. And yet a very local source of steel is on the radar. Hehehe!
I believe, with the help of the young fellas at the tire store, The 15-32 rear tires on old No.2 can be saved and used for a long time. Some boots will be needed. We'll see.
OK, as I understand it, 15x32 tires are few and far between. OK.
How about solid rims? Any thoughts? The left rim is holding on but very thin on the bottom where he sat for a long time. Fluid in the tires. The right rim is garbanzo beans. George Carlin once said "I ain't eating nothing with the first four letters of garbage in it!"
I'd like to cut the right rim off and weld a good rim back on as I've gotten used to the rubber still here. The son wants to pull this tractor too. I can't blame him. If you break it son, fix it.
We'll see.
Point is; a set of good 15x32 rims will take care of things...
Cripes, old #2 isn't even running again yet. Yet.
The Following 3 Users Say Thank You to Duey C For This Post:
  #78
Old 09-24-2018, 10:10:15 AM
Russ Hamm's Avatar
Images: 1
Your 32" tires and wheels are pretty good I take it, the WK40 and 22-36 McCormicks run those also so ive had to collect up some of those for friends over the years. My 32" supply is down to a few rims now. I run steel wheels on everything now, but over the years I tried to buy 30" duals at farm sales and then found a pair of 30" 22-36 cutoff rears but we have never done anything with them. The steel lugs sure take some power away compared to the rubber tires, but I sure hate flat tires and dead batteries.
The Following 2 Users Say Thank You to Russ Hamm For This Post:
  #79
Old 09-24-2018, 01:50:52 PM
ajs2744TC ajs2744TC is offline
Just need to get those used decent fenders and platform I mentioned to you and tires and it's plowing time. 32 are hard up here as well to get. Keep an eye on Craigslist or farm sales. Those tires didn't seem to dry cracked and may be saved.
The Following 2 Users Say Thank You to ajs2744TC For This Post:
  #80
Old 09-25-2018, 12:15:16 AM
Russ, those rear Good Yearís are pretty nice for what they are. I too HATE flat tires and dead batteries... :-) On steel is just plain easier.
Adam, youíre right as usual. Those tires are not dead yet at all. Itís as if time left them be as they were for awhile. Even under the blown tube on the right, that tire is taking it well. Yes, there is damage but theyíre still ďsoftĒ.
Oh man, the platform on this olí guy is rough ainít it?
It worked for a long time for the users but it is time to take old #2 back to where heís fairly correct as he was back then. I need to break out of my box and go north-west and get the parts. You did the leg-work, now I should finish it.
The local source for wheels isnít looking good. He has McCormick wheels I think.
Unless more info comes to the surface about engine numbers and engine casting numbers throughout the FE engine time frame, Iím calling this FE-1-H engine a replacement engine with GE-1 cylinders from 44 with potentially original heads and covers. Going to say it because I mean it. Cool beans. :-)
Hahaha! Iím still posed with issues. Do I dare pull an 8000 pound slow moving boat anchor up this hill with my motor grader or glide a free rolling 8000 pound tractor (with an emer brake thatíll bite ya in the butt sometimes) up this same hill. Whoíll ride the tractor?
Iíve turned into a ďno mistakesĒ kind of fella. Double sets of chains (if one gives out) and will the eight, 1ď cold rolled pins in the rear hitch of the grader have the mustard to do it? Where else do I hook to? The drivers. Does the 100 horse IH Diesel engine actually have the snoose to do it? Heck of a load on the way up. And support machinery to stop a mishap
Adam, youíve seen this hill. Iíd value your input about it.
Iíve also loved my time down there with the 21-32. A model T friend would give me heck about NOT using the T yard truck here but he doesnít have a stereo. I have my tools and what-not on the rear leather seats of my Buick! Pretty nice go kart.
Oh oh. If you live in these areas, check for water yearly at least! Pull your water pump packing nuts too. You folks taught me that.
ID:	319503   Click image for larger version
Couple 20-35 Twin City Tractors Rescued mmtractor1950 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 16 07-02-2017 12:22:20 AM
100+ Antique Tractors and Stationary Engines John Deere, Empire, Twin City, Wallis + SteveBranch Live Auctions of Engines, Tractors and Old Iron 0 09-11-2015 05:26:43 PM
Twin City tractors followed me home Ben Zimmerer Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 7 11-06-2014 09:21:21 PM
Bought a pair of Twin City tractors Nebraska Kirk Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 15 07-14-2014 04:50:10 PM
Flat belts for Twin City Tractors patchen1 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 9 08-21-2011 02:23:16 PM
