Twin City 20-35 Prototype?
this thread has 65 replies and has been viewed 7868 times
Old 01-09-2016, 12:53:22 PM
Default Twin City 20-35 Prototype?
I have a question about this picure that is in the book "Twin City Tractor Photo Archive" by P.A. Letourneau. The picture shows a storage room filled with early 12-20 Twin City tractors. But the tractor in the foreground is not a 12-20. The fuel tank and saddle look like 20-35 parts to me. But then on the motor there is an early "12-20 style" intake manifold with a Pierce governor assembly. Also note the unique hand hole covers on the block.
If this is a 20-35 some of these parts do not show up in the 1924 repair parts list No. R-721. However the engine physically looks too tall and the hood too long to be 12-20 stock.
Any insights?
Name:	Twin City 20-35 001D.jpg
ID:	243313   Click image for larger version
Name:	Twin City 20-35 003D.jpg
Old 01-09-2016, 06:44:21 PM
Jeff Blaney Jeff Blaney is offline
Default Re: Twin City 20-35 Prototype?
It is very possible. From what I understand the 20-35 was still in the design stages throughout the late teens and was finally made available to the public in 1920 (the same year the photo was supposedly taken).
It is difficult to tell due to the tractor being in the foreground and its bottom half out of the frame. Those monster front wheels would give it away instantly. From my perspective it does look larger than the 12-20's pictured behind it, especially when you consider the gas tank and height of the fenders.
Awesome observation by the way. I've studied that picture many times and never picked up on this.
The Following 2 Users Say Thank You to Jeff Blaney For This Post:
Old 01-09-2016, 11:43:02 PM
Yes that intake manifold does throw a guy for a loop. A person automatically assumes that it's an early 12-20. However on the 12-20's and 17-28's most of the steering wheel and the top part of the brake lever can be seen over the top of the fenders from a side view. On a 20-35 only the top portion of the steering wheel can be seen. The controls are clearly in the right spot for this to be the first of the big twin cams.
The Following 2 Users Say Thank You to Mark Schneider For This Post:
Old 01-10-2016, 01:19:48 AM
Phil Johnson's Avatar
I wonder what that one used for valve lubrication? There are no oilers visible through the hood as there are on all the 12-20s in the picture. I also think that this may be a 20-35 prototype due to it's size and already mentioned features..
It'll be done in good time---impossible might take a little longer!
The Following User Says Thank You to Phil Johnson For This Post:
Old 01-10-2016, 08:47:20 AM
Stuart Landry Stuart Landry is offline
Looks like 20-35 size tractor,
As the bottom tank of radiator is cast with the engine support frame ,i think the smaller TC tractors have a separate bottom radiator tank ?
Old 01-10-2016, 10:47:49 AM
Mark,
You are definitely a detail oriented person!
I got my first photo archive book in 1994 and studied it so hard under bright light and magnifying glass that I wore it to pieces and had to get another copy.
You are correct, that is an early short fender 20-35.
The block and head set are very different in much more than size between the big and little tractors. The first 20-35's appeared along with the TC trucks (there is one sitting behind the big TC) and had rear wheels with a rolled edge like 12-20's.
The books were a great photo source, however, they had painfully incorrect text that did not even match some of the photos...that photo may have been taken in 1919?
Tony
The Following 9 Users Say Thank You to Tony Thompson For This Post:
Old 01-10-2016, 12:21:58 PM
Phil, I imagine that the oilers were placed beneath the hood on this prototype. I couldn't see MSM equipping these prototypes with a pressurized system like those on the 27-44 and then move backwards, equipping production tractors with drip oilers?
My 27-44 has cut outs on the hood for drip oilers yet it has a pressurized system. I figure there was an old hood in the parts pile when my machine was assembled.
The Following User Says Thank You to Jeff Blaney For This Post:
Old 01-10-2016, 05:36:27 PM
Here is another interesting picture of the Twin City 20-35 prototype from the book "Twin City Tractor Photo Archive" by P.A. Letourneau. It is incorrectly labeled as a 12-20 but it is clearly the 20-35 prototype during a in-field testing run. Note there is no air filter on the carburetor and no lugs on the rear wheels making it unlikely that this unit was sold to a customer.
There are a couple of clues that the engines in these prototypes were different than the ones that ended up for sale. One is that the original engine size may have been 5 1/4"x 6".
Name:	Twin City 20-35 004D.jpg
ID:	243399   Click image for larger version
Name:	Twin City 20-35 006D.jpg
The Following 11 Users Say Thank You to Mark Schneider For This Post:
Old 01-10-2016, 05:51:50 PM
OTTO-Sawyer's Avatar
Originally Posted by Mark Schneider View Post
...... It is incorrectly labeled as a 12-20 but it is clearly the 20-35 prototype during a in-field testing run. Note there is no air filter on the carburetor and no lugs on the rear wheels .....
and as you noted earlier..... On a 20-35 only the top portion of the steering wheel can be seen...
Old 01-10-2016, 09:46:39 PM
This photo is poor,
I hope it shows up good enough to see one of the rare early 20-35 short fender
TC's. The first few had rear steel with rolled edges on them like 12-20's. Regular production rears were thicker with a squared off outer edge.
The "TC" letters cast into the top radiator tank was smaller on the early short fender models as well. The fenders were actually 12-20 fenders that were re-arched or stretched open to match the large diameter wheels of the big tractor.
Tony
Name:	Short fender 20-35.jpg
The Following 11 Users Say Thank You to Tony Thompson For This Post:
Twin City 17-28...My Intiation into the Twin Cam Faternity! Mark Schneider Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 120 06-01-2018 09:21:55 AM
Twin City KTA ozfarm Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 07-24-2014 09:10:50 PM
Twin City KT Ben Zimmerer Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 06-17-2014 11:11:19 PM
My first Twin City Rick Schmitz Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 180 04-24-2014 03:19:16 PM
Twin City KTA ssimntih Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 18 07-02-2011 09:58:18 PM
