Removing Valves from Novo S Engine?
this thread has 2 replies and has been viewed 1138 times
Old 11-21-2017, 06:15:47 PM
Larry K Larry K is offline
Default Removing Valves from Novo S Engine?
What is the process for removing the valves on a Novo S engine? The nut came off, easily, but what is the process for removing the valve?
Thanks.
Larry Kastens
Old 11-21-2017, 07:27:16 PM
Tom Gosciminski Tom Gosciminski is offline
Default Re: Removing Valves from Novo S Engine?
If the nut is off the valve and cage should pull right out, spray some penetrating oil up into the cavity. There should also be a copper ring gasket at the top of the bore to seal the valve seat.
The Following User Says Thank You to Tom Gosciminski For This Post:
Old 11-21-2017, 11:17:21 PM
David Babcock David Babcock is online now
Smile Re: Removing Valves from Novo S Engine?
Soak it. Give it some time to loosen up the rust and carbon before you reef on it. Novo valve cages are fragile. Db.
The Following User Says Thank You to David Babcock For This Post:
removing ideal valves Eric McKenna Hit & Miss Gas Engine Discussion 3 07-18-2013 07:07:06 PM
Removing Tag from Engine DaveTexas Hit & Miss Gas Engine Discussion 10 06-12-2012 12:08:41 PM
Novo valves OldironPhil Hit & Miss Gas Engine Discussion 7 09-30-2008 03:53:56 PM
Piston Valves / Slide valves - Preferences? ListerDiesel Steam Stationary Engines, Traction Engines 3 03-25-2008 09:49:00 PM
Novo engine valves leaking gas? Dan Hickel Hit & Miss Gas Engine Discussion 9 11-17-2007 11:05:40 AM
