Roper YT160CR / Yard-works info.
this thread has 1 replies and has been viewed 3200 times
Old 07-03-2006, 10:58:15 AM
jrobbins jrobbins is offline
Default Roper YT160CR / Yard-works info.
Hi, I'm picking up a Roper Yard-Works riding lawn tractor or lawn mower?
(I do not know the proper term.) Model # YT160CR / Serial # 3225501265
I was not able to find the numbers on the 16 hp dual cyl. I/C Briggs & Stratton, any info. or sites you can lead me to would be great!
I do not know the year, or if I can find a manual, ect.
Thank-you
Old 07-03-2006, 02:42:53 PM
John Newman Jr.'s Avatar
John Newman Jr. John Newman Jr. is offline
Default Re: Roper YT160CR / Yard-works info.
A B&S 16hp twin will probably be a Model Number 40XXXX. The first digits of a Briggs model tell you the cubic inches. The following digits of the Model Number plus the Type Number specify if it is horizontal or vertical shaft along with the starter, bearings & carb options. The first 6 digits of the Code Number will tell you when it was made - Year, Month & day. These numbers will be stamped in the tin shroud (I believe...) on the right side cylinder when facing the carb side of the engine. Knowing when the engine was made will get you somewhere close on the age of the tractor.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
sears roper need info put put man Garden Tractors and Mowers 5 09-21-2013 09:20:50 AM
Info about iron wheels in my yard slick781 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 18 08-14-2011 12:58:47 PM
Table saw for Hiller yard Hand INFO Brian.P Hit & Miss Gas Engine Discussion 1 05-28-2011 03:20:00 PM
1869 Roper caloric engine info & engraving Culy Hot Air Engines 4 03-05-2010 12:57:18 PM
Hiller Yard Hand Tractor info K.Watkins Small Air Cooled Gasoline Engines 4 04-16-2006 11:01:43 PM
